Project GO FAST is now in progress!!!
Old Oct 1, 2007 | 08:59 AM
  #121
MGDfan's Avatar
Originally Posted by ONELOWF
Deja vu - (sp) - Bigtruck311's thread - see post # 45 by WLF.
https://www.f150online.com/forums/sh...t=knock+sensor
Yes - but see Mad's post # 44.
Also, WLF did not have a full Lightning swap ( Is this correct?) - I believe Built does ....
Old Oct 1, 2007 | 10:28 AM
  #122
Green_98's Avatar
You have an awesome truck man...that thing is going to be sick!
Where is Doe Run Missouri? Im originally from Fulton; went to college in Warrensburg...
Old Oct 1, 2007 | 03:19 PM
  #123
SlammaJamma's Avatar
Built, take the week off and finish this thing already
Old Oct 1, 2007 | 03:38 PM
  #124
jbrew's Avatar
Built - I read thru the thread those guys posted - lightninigs are setup different - I learned quite a bit reading about the knock sensor there - You even posted in that thread - I think your around post 70
Great Info!!
Old Oct 1, 2007 | 04:22 PM
  #125
SMIGGS's Avatar
Aw man, I'm so jealous. I would love to have that motor in my Expy.
Make sure you have the camera going on her maiden blast down the highway. Gotta love the whine of a supercharger!
Don't you know if you had used a 4.6 you would have got 100 hp more out of that set up?
Old Oct 1, 2007 | 04:29 PM
  #126
JMC's Avatar
JMC
25 Year Member
If the MAF wasn't plugged in it would use failed maf tables to control the fuel. I would you check for a vacuum leak. Look closely at the PCV system o be sure all the tubes are plugged in.
JMC
Nice set up BTW
Old Oct 1, 2007 | 04:41 PM
  #127
Zaairman's Avatar
Over by Farmington.
Old Oct 1, 2007 | 05:21 PM
  #128
Veteran: Army
Old Oct 1, 2007 | 06:21 PM
  #129
built54's Avatar
yeah right by farmington, mo. Ok glad to hear the knock sensor isnt needed. that saves a LOT of work. Im going to check that IAC and vacuum lines and all the obvious, ill get back with ya!
Old Oct 1, 2007 | 10:50 PM
  #130
scottbigred's Avatar
project go fast seems to be movin kinda slooooow lol
definatly one cool truck built i wouldnt mind the wheels and tires and motor for my truck. im a fan of red so i couldnt take the whole thing lol
Scott
Old Oct 1, 2007 | 10:51 PM
  #131
twintips_17's Avatar
Scott
I think we all would take the powerplant. Still waitn on an update built54
Old Oct 1, 2007 | 11:19 PM
  #132
built54's Avatar
well it can idle!!! I cleaned the IAC, didnt do a darn thing. I messed with my tuner, didnt do anything. I thought, what about that little screw on the tb.... well I turned it in, and it didnt do much, but it did idle higher, and it would still die, but I started it and shut it off several times, and I guess it learned it, and now it will idle. I did a little data logging, and I'm pretty sure its pig rich. I recalibrated my wideband twice, and im getting 7.7-10 at idle and driving around. And as soon as it gets in boost, it pretty much falls on its face. I emailed the logging to my tuner, and ill talk with him tomorrow.
Old Oct 1, 2007 | 11:48 PM
  #133
jbrew's Avatar
How old are your front 02's ? You prolly know this , I was reading that thread MGD & ONELOWF posted last night - said running rich can screw them up purdy quick.
Good luck with the tuner - hope he's available to give yuh a hand right away..
  #134
Faster150's Avatar
whos doing your tunes?
Old Oct 1, 2007 | 11:53 PM
  #135
built54's Avatar
JJ@wms
