6.8 V10 stroker
Old Sep 20, 2007 | 06:54 PM
  #151
Faster150's Avatar
Originally Posted by built54
uh we do
ha in 2nd gear with 87 octane and 15. a/f ratios. but not in 3rd with 93 octane.
Old Sep 20, 2007 | 06:57 PM
  #152
B-Man's Avatar
Originally Posted by Faster150
ill say it for the 4th time.. my RWHP numbers were in 2nd gear making my 3rd gear rwhp numbers much higher. your rwhp numbers on stock motor was 251 and if im making 242 in 2nd gear doesnt that make your heavily modded 5.4 weaker?
"1999 F-150, 5.4, N/A 251RWH.P/330RWTQ = R.I.P
New BUILT 5.4, N/A 354RWH.P/392RWTQ
Turbo set-up in the works! T76-GTS."
OK jacka$$ - Why do you constantly try to compare your 2nd gear numbers to anything else ?
If the dyno is calibrated correctly AND the operator knows how to run it correctly AND the test is done with all parameters being input correctly, the HP output of the engine will be nearly the same in either 2nd or 3rd gear.
That is why you can measure the power output of cars with way different gearing and the measurements are still meaningful. The dyno takes into account speed, RPM and time. The result is a calculation that uses all three variables.
In your example, your RPMs would be high, your spin-up time would be shorter than if in 3rd, but your speed would be way down. Do the math and the power output is revealed...
Stop being stupid - the 5.4L makes more power, period.
I am still amazed you constantly go out of your way to make yourself look like a mental midget... Give it a rest already.
Old Sep 20, 2007 | 06:58 PM
  #153
Veteran: Army
wouldn't they be higher in 2nd than in 3rd due to the gearing?
Old Sep 20, 2007 | 07:03 PM
  #154
Faster150's Avatar
ive posted several times what the difference between 1st 2nd and 3rd gear dyno numbers come out to be. the numbers i posted were not doing a power pull it was during a tunning session where i only took the motor up to 4800rpm. no 5500 which is my shift.. dynoing in any gear higher than 1:1 ratio changing rear end gearing or tire size effects the amount of power a dyno will read at the rear wheels. ive never been to one dyno shop that inputs all of the variables to read correctly. most of them just throw them on there and get a reading. in 1st gear the engine isnt working as hard. in 2nd its working harder in 3rd its working its hardest highest fuel demand so on so forth thus is generates the most power. think of it this way if u want to read damn near what the fly wheel HP - transmission loss is. hook the drive shaft straight to the roller and u will read it. but when ur reading from the wheel its less. because your spinning a gear that either makes the load on the engine less or greater along with tire. a taller tire will register more power than a smaller tire.
Old Sep 20, 2007 | 07:08 PM
  #155
Faster150's Avatar
http://www.eiptuning.com/eip/video/R...00_HP_0001.wmv
watch the mountain climb as the gears go up. power needed to move the vehicle increases as u accelerate thus the engine produces more power. same reason why u dont really see peak boost untill ur in 3rd or 4th gear if u are turbo'd
Old Sep 20, 2007 | 08:02 PM
  #156
Veteran: Army
whatever
Old Sep 20, 2007 | 08:19 PM
  #157
JMC's Avatar
JMC
25 Year Member
Faster150,
You should never have stopped taking the short bus........
JMC
Old Sep 20, 2007 | 08:50 PM
  #158
Neal's Avatar
Cool
HI!... Well when I tried dynoing my truck in 2ND gear my #'s were higher than in 3RD gear. HMMMMMMM.
BTW untill you ACTUALLY run your truck in 3RD gear on the dyno, your #'s mean absolutely nothing, like much of what you say..............
Old Sep 20, 2007 | 08:52 PM
  #159
Neal's Avatar
Cool
Originally Posted by chester8420
You guys crack me up! It's like middle school all over again!
OOH.... You got Janked on!
"YO MAMA!"
Keep it up guys!
P.S. Neal, My truck runs between 8 and 9:1 a/f on WOT, but when I get up and around the 4,500-5,000 range it starts leaning out.... to 10.5 or 11:1 ... Do you experience this with your truck? Or does it stay at a set a/f ratio? Thanks!
HI!... My truck ran 14.7A/F at idle and 12.9-13.2 at WOT. The A/F ratio will move up and down as you move the throttle. But if your throttle is constant than so should your A/F reading.
Old Sep 20, 2007 | 08:54 PM
  #160
Neal's Avatar
Cool
that is really rich is needs to be between 13.5-14. at WOT if ur n/a
HI!... For N/A you want 12.9 - 13.4 A/F at the most.
Old Sep 20, 2007 | 09:06 PM
  #161
stopper's Avatar
Originally Posted by JMC
Faster150,
JMC
I have to type this with one arm because I fell completely out of the chair and hurt my other arm!!!!!
Old Sep 20, 2007 | 09:41 PM
  #162
Faster150's Avatar
u speak so much but have no proof not even a dyno of your all mighty 5.4 that didnt last a couple months
Old Sep 20, 2007 | 09:42 PM
  #163
Faster150's Avatar
Faster150,
JMC
the short bus how did u find out about those isnt that all they have up there?
Old Sep 20, 2007 | 09:48 PM
  #164
Neal's Avatar
Cool
HI!... I have all kinds of proof. Dyno vids, dyno charts, dragstrip vids, E.T slips.
It's just KILLING you that I won't post them up, doesn't it?
That's my whole point. bwaaaaaaaa!
Old Sep 20, 2007 | 09:50 PM
  #165
Neal's Avatar
Cool
HI!... Only the retards take those buses. That's why JMC thought you rode in one........ everyday
