Which Walbro??
Which Walbro??
Which model number is the correct intank pump? I see a lot of choices but not quite sure which one fits my 2002 5.4. Will this pump be ok with a Vortech? I'm about to add one. Do I also use the T Rex or just leave it out if I get the Walbro? Or is the stock one and the T Rex good enough to supply the fuel?
I wouldn't add a used fuel pump to your already used fuel pump. I think this one is a plug and play version, but may require slight modification to the in tank bracket. The swap is about a 4 hour job on jack stands, but not too difficult.
http://cgi.ebay.com/ebaymotors/WALBR...spagenameZWDVW
Originally Posted by derrick929
"BSFC"? I'm new to this so you lost me.... I don't think I'll make over 500 so the 255 should be good......unless this really gets out of hand.....
