AT LAST! finally ordered some cool stuff....
Old Jul 24, 2007 | 07:18 PM
Kevin24's Avatar
Ya the flows made my truck real sluggish off the line
If ya have one put it on,maybe you will like the sound better
I don't have the new style 150 but i think the exhaust is 2 1/2
Kevin
Old Jul 24, 2007 | 07:19 PM
jbrew's Avatar
As far as long tubes - Call the manufacturer - They can help you out there for sure. Bad thing is, your prolly lookin at $800 + . Honestly , you get what you pay for - I'm positive you can get some for the 04 +.
As far as Troyer . I like his blower kits , but he's pricey. I get the same stuff 25% cheaper at the other suppliers (Autopartswarehouse.com & Performancepeddler.com)
The Blower kits @ http://www.madenterprise.com/scparts.htm.
Auto parts warehouse offers free shipping with purchases over $50 . Performance peddler does not. What makes that so great is with the peddler you can make them a best offer and submit what your willing to pay and they really want your buisiness.
You can go back and forth between the two venders a get the stuff dirt cheap sometimes. You never pay retail that way.
Kevin - My email changed - The MAC addy doesn't work . Same address but use @earthlink.net.
Old Jul 24, 2007 | 07:26 PM
Kevin24's Avatar
Ya i don't think it worked when i tried sending it,so i tried a PM and it said you exceeded messages,damn thing
Old Jul 24, 2007 | 07:36 PM
jbrew's Avatar
Kevin
I reduced mine to 2 1/4 from the manifold back to the crossmember attempting to balence the backpressure needed - I don't have rear cats , my forward cats are 2 1/4 as well. It's pulls like hell now but I still have to much flow. I think I'm going to add the maggy high flows and see if that fix's it - My check engine light is coming on . The system clamped and it has to leaking a little . I could try to weld it up . I think I'm just going for the high flows to see what happends.
Kevin , remember my trans use to slip off the line, for almost a year. That Transgo kit and Amsoil fixed that . I can torque (both tires) for a warm up- no problem now.
I noticed the 01 that I'm using has a 8.8 rear gear and a 5four - It's stock , It's takes alot more effort to get them tires turning . My 98 w/9.75 rear gear starts torqueing the tires just above idle ...
Old Jul 24, 2007 | 07:37 PM
jbrew's Avatar
Ok , I'll delete some here..
Alright - DELETED
Old Jul 24, 2007 | 07:50 PM
jbrew's Avatar
Originally Posted by dennisfranz
I've also read the underdrive pulley are not a great bang-vs-buck bolt-on HP mod. There is just not any significant boost vs the cost. Also since you are using the eFans an underdrive on the charging and in lots of stop-n-go traffic, that may pull a big load if the charging system if it is running significantly slower.
I hear yuh there - by far the best bang for the buck is gearing for torque and it doesn't beat you up as far as economy which is a big plus if it's your daily driver.
Stock - Oversized (one size over) with the rubber - 4.10's would be choice
Old Jul 24, 2007 | 11:03 PM
Faster150's Avatar
im porting out a throttle body and plenum off of a 4.6 06 F150 it was to go to a friend of a friend but i dont think he wants it. the throttle body is being ported from the stock. 62mm to 70mm. so ur gonna see a good bit of a gain from it. if ur interested let me know
Old Jul 25, 2007 | 01:36 AM
seidita84t's Avatar
to: Faster150, how much?
to: everyone else, took off the 40 and threw on the old glasspack i had layin around($20 cherry bomb), just as loud outside, less resonance inside, and a decent amount more pull off the line, by the way, the 40 and the glass pack are both just dumped under the bed. but anyway, thanks you guys, i'll be investing in that magnaflow as soon as i get some bucks in the pocket, thanks alot.
Old Jul 25, 2007 | 07:35 PM
Faster150's Avatar
75 bucks plus shipping sound fair?
