Motor cleaning and degreasing.
Do any of you know of a good way to clean oil off of the back of a motor and tranny bellhousing? I have a pretty bad oil leak, and I need to clean everything off under there so I can even tell where it is coming from. I was hoping I wouldn't have to do it with spray stuff and shop towels.
Thanks,
Hunter
Thanks,
Hunter
on
Thanks again guys! I'm going out right now to try to pinpoint the leak. I suspect that it is the driver's side valve cover (I hope it is, as this is the easiest one to get to). I'm hoping that it is not the rear main...That is a job I probably can't do myself.
I'll let you know how it turns out.
Thanks,
Hunter
Thanks,
Hunter
