Recommended service with 107k miles on a 1999 F150 4x4
I just purchased a used truck from a dealer so not sure what service it's had done to it so I want to go through it. Here's what I plan replace or service.
Spark Plugs
Drive Belt
Shocks
Fuel Filter
Hoses and Coolant
Transmission Flush and Filter
Transfer Case Fluid
Front and Rear Differential Fluids
Brakes, Air Filter, Oil all fine
Let me know if I'm missing anything or if some of them don't need to be replaced or serviced yet.
Thanks,
Mark
Spark Plugs
Drive Belt
Shocks
Fuel Filter
Hoses and Coolant
Transfer Case Fluid
Thanks,
Mark
Spark Plugs
Drive Belt
Shocks
Fuel Filter
Hoses and Coolant
Transfer Case Fluid
Thanks,
Mark
Spark Plugs
Drive Belt
Shocks
Fuel Filter
Hoses and Coolant
Transfer Case Fluid
Thanks,
Mark
Originally Posted by ruger43
That about overs it. Add PCV valve to it. If you are doing the plugs, it wouldn't hurt to pull the throttle body and elbow to clean the body and egr ports. Also gives you a little more room when changing plugs.
http://www.fordf150.net/howto/throttlebodyclean.php
Try this link. It might help you on how to take it out and how to clean it. I done it last summer. Wasn't to bad. Good Luck!
Originally Posted by keith97xlt
pull the front passenger plug and check it out first. chances are they might have already been done. if they look good leave them alone.those are a pain to change. all the rest is pretty simnple stuff.
What motor do you have? If its a 4.6, then new plug wires and new coil packs would help. If its a 5.4 and you've got the $$$, some new COPs would be nice. I got all of my ignition stuff from Troyer for my 150. And I think it'd be best to change the oil, filter, and air fiter anyways just to be safe. Who knows what crappy stuff they used... And to clean the throttle body, just use plain old carb cleaner. Yes, there is TB spray, but after 8 years, that "special coating" is long gone. And also, do a search on here for Seafoam. Does wonders.
Originally Posted by Zaairman
Chances are they haven't been changed. They're not too bad, I did mine in about 3 hours.
