i belive my valves are knocking
Old 03-27-2007, 09:28 PM
chfan007's Avatar
My valves are are geting pretty loud is this a hard fix
Old 03-27-2007, 10:30 PM
chris1450's Avatar
I doubt you hear your valves. What engine is in your truck. Discribe the noise better. Is it at engine speed? or is it half that speed... the cam turns half the speed of the crank. You didn't give much info.. so hard to troubleshoot here
Old 03-28-2007, 06:42 PM
chfan007's Avatar
enginge noise
[QUOTE=chris1450]I doubt you hear your valves. What engine is in your truck. Discribe the noise better. Is it at engine speed? or is it half that speed... the cam turns half the speed of the crank. You didn't give mucch detail
Its only when excelerating, noise from top end maybe rocker arms or somthing
Old 03-28-2007, 07:06 PM
Faster150's Avatar
likely piston slap.. is it a 5.4? if ur valves are ticking... it will only do it for a short time like couple RPM.. then the valves will chip off and the motor wont have enough compression to keep spinning
Old 03-28-2007, 10:08 PM
chfan007's Avatar
if i run higher grade gas its not near as bad
Old 03-29-2007, 01:41 AM
jetfumes's Avatar
I thought I had the same problem, and after reviewing this site, which by the way is a great help, noticed it was the piston slap. But after a further investigtion, found out it was the rod bearings, replaced all of them and now working fine. the problem I had was during cold startup would hear what I thought were valves, also would hear it under hard acceleration, around the 3500rpm mark, but again fast or hard acceleration. If you do a search on the 5.4 and piston slap you'll find much on this, but don't let it fool you into not looking into it being something else.
Old 03-29-2007, 09:19 AM
Norm's Avatar
Then it is detonation (pinging) and not mechanical. Valves and rocker arms do not care about octane.
A new truck should not be pinging like that, head on back to your dealer and see what they say.
Old 04-01-2007, 11:08 PM
chfan007's Avatar
Thanks i will check into it
Old 04-01-2007, 11:11 PM
chfan007's Avatar
Yes it is more like a ratle or ping like you said i just bought the truck on ebay did not start it untill recently
Quick Reply: i belive my valves are knocking
