Is my block cracked? pics here
Hope i did these picturs right, basicly it is a lifted type of a crack, at first i thought it was a layer of rust peeling off, but it is pretty solid
i tried to color with a crayon so you could see the darl area of the crack , it seems to run up and down along with the back side of the cylinder jacket(valley side)
its just funny it happens to be th esame side that popped the rear passenger side freeze/core plug..
here is that thread:
https://www.f150online.com/forums/sh...d.php?t=276717
well guys, i really havnt seen blcok damage from expanding ice.
does this seem like it could be the result?
not sure how else to test now, short of pulling it apart and bringing it to th emachine shop
looks like a head check and new bottom end is in order
any help is greatly appreciated
Chris(with an almost rebiult 98 F-150)
Like so
Originally Posted by Faster150
yeh its cracked...
i guess i should came up with a different title..i have never seen an ice crack before, trying to confirm ,\
i also guess, ice or no ice , it doesnt look good, i can only assume it goes right through into the jacket
thanks
Chris
jbrew, chester8420,GIJoe Cam, faster 150,
thanks for the replies!!!!
GIJOECam, it wasnt leaking anything before the winter, but it hasnt ran since then either so the cooling system never got presurised again ..so hard to say,it started leaking out the rear freeze plug before i ever got that far and decided to pull it, and this was upon filling the system, never got to run it..
i automaticly assumed it went hand in hand with the freeze...hard to say if these cracks were there before or not..
unless i could get some proof that this is a common thing and doesnt eefect the cooling system, i am considering it junk at this point..
sealing the crack is one thing if this is the only damaged spot, but if its on adjacent cylinder walls to, well then its done ..
only way to tell now is tear her down
, i was hoping not, but it doesnt look good..160K on the clock, previous head gasket jobs, rusty gunked up coolant passages, maybe this will be a good thing ..lol
Faster150, ya, i had been told and read many times welding and cast iron is a hard task, and considering this is the result of a water freeze, i am concerned there is damage elsewhere..it is the same bank the plug popped on
thanks a bunch everyone, i am a little uncertain here, but i think i am headed in the right direction, by not trusting it..
maybe i will get lucky and th elocal machine shop will have a 4.6 block hanging around, that my rotating assembly will fit in(providing cleaning and polish is all it needs), new bearings, rings, new bottom end...if i could be that lucky
Thanks again
Chris
Thanks again
Chris
Thanks again
Chris
Thanks again
Chris
although i may be able to entice the e-bay idea?
plus if your patient, i have hopes n dreams to have my tired 4.6 yanked and a neat lil 5.4 stuffed in there soon.
hey Klitch, Faster150,golfmjs777,
thanks for the replies made a few calls today
local boneyard wants 1500 for a 109K long block
local machine shop has 2 used motors in wich he may sell me the block
other wise they will sell me a rebiult with 3 yr unlimited mile waranty for 1500
only catch is i am unsure if that was a long block price or not
so i am going to tear her down and inspect and measure everything , let the machine shop check the heads and work on the short block deal
if that doesnt work out looks like a rebiult from them is the best bet, pretty sure i can handle puting this motor together, but it is early to tell yet
thanks
Chris
thanks
Chris
