ford mech. cant help can u
Old 01-20-2007, 03:23 AM
bluebullet37's Avatar
Unhappy ford mech. cant help can u
I bought my 99 f150 4.6 liter 2wd a year ago and Im still having the same problem. Driving around at any speed the rpms will jump up to 4000rpms and then back to normal. Sometimes I will be at a red light or a stop sign and the rpms will shoot up and the truck will lunge forward. (SCARY!!!). At times while Im driving around the engine will just die and I have to pull over take out the key put it back in and restart the engine. The odometer will black out also. Ive had it at ford dealership 4 times now. Ive replaced the plugs, wires, coils, and the alternator by there request, but it hasnt changed a thing. I love the truck but it is not very safe to drive my 3 kids around in. Please somebody help me!!! I cant afford to keep going back to ford to replace things that dont need replaced.
Old 01-20-2007, 03:34 AM
Klitch's Avatar
sounds more like something deeper than the items you've looked at...
computer related perhaps?
Old 01-20-2007, 03:45 AM
what about some basic electrical stuff, like engine block and chassis grounds?
Old 01-20-2007, 03:50 AM
Klitch's Avatar
im not seeing why that would cause the rpms to surge on their own?
Old 01-20-2007, 03:59 AM
Maybe the computer isnt getting suficent power, so it thinks the alternator isnt giving enough power, so it jumps the RPMs. I dunno....
Old 01-20-2007, 04:04 AM
Klitch's Avatar
ok ok, but 4k seems excessive?
still would be an easy fix and is probably a good idea to do in this situation anyways. try it, but im still leary of the computer its self.
Old 01-20-2007, 04:05 AM
agreed, im just tryin to think of something that might be overlooked, or underesitmated by a ford mech
Old 01-20-2007, 12:32 PM
racerf150-2's Avatar
try a tps and check wiring going to it. if its shorted or anything that will give a mixed signal to the comp and would send rpms that high
Old 01-20-2007, 01:33 PM
Bluegrass's Avatar
Consider this; the engine has to have increasing air and fuel to accelerate in such a manner. I would look hard for physically loose throttle body, top TB manifold, intake manifold and/or gasket leaks. This air has to come from somewhere when the foot is off the throttle.
The PCM, ignition etc only react to a request to accelerate the engine and could hardly be the root cause but will do as it is commanded by sensors, air and the right conditions present..
Quick Reply: ford mech. cant help can u
