Oil recommendations for older F150
I have a 1994 F150 5.0 with 80K that I use periodically for chores, errands and towing a camper or boat. I am interested in knowing recommendations for oil viscosity for winter and then summer. I am not interested in going synthetic. I change the oil and filter every 3K miles and since I've passed the 75K mark, wondering what are the best brands and types to use given my driving/usage of the truck?
Thanks!
Thanks!
if its an older engine, get something with some good detergents in it. i use trop artic in my engines and it keeps them extremely clean. research some name brand manufactures and see what the detergent content is in them. good luck!
Broke?
Thanks!
Thanks!
Thanks!
Thanks!
I usually buy what seems to be the best deal as long as it is API aproved and and is in accordance to the Ford F150 manual's recommendations. I haven't tried the high mileage oils andwondering if they realy make a difference? I'm not going to switch to syn from dino at this point in the truck's life. So will likely keep doig what I'm doing using 5W30 year round unless I do some towing and I'll up the grade to 10W40.
I usually buy what seems to be the best deal as long as it is API aproved and and is in accordance to the Ford F150 manual's recommendations. I haven't tried the high mileage oils so wondering if they realy make a difference? I'm not going to switch to syn from dino at this point in the truck's life. So will likely keep doing what I'm doing using 5W30 year round unless I do some towing during the summer and I'll up the grade to 10W40.
Adrianspeeder
