Gutless!
Old Oct 18, 2006 | 11:15 PM
CAkid88's Avatar
Unhappy Gutless!
I just traded my 2000 F-150 SCab XLT 5.4 in for a 2001 F-150 SCrew Lariat 5.4. My 01 seems gutless, compared to my 00. Is it because of the extra weight, or how it was broke in? Besides the superchips, and expensive add-ons, is there something I can do?
Old Oct 19, 2006 | 11:08 AM
Zaairman's Avatar
Tune up (plugs, COPS, fuel filter), exhaust, intake, and a tune.
Old Oct 19, 2006 | 11:41 AM
2stroked's Avatar
What rear end gear did you have and what one do you have now? That can make a huge difference.
Old Oct 19, 2006 | 04:59 PM
RaWarrior's Avatar
Check the axle code on the driver's door. Axle ratios tend to come higher standard in the interest of better fuel economy rather than performance. The 2.73 axles are a real dog, but good for the highway. There's 3.08, a little better, and the heavy-duty 3.55 is for hauling. A truck can have the same motor, same trans, and drive totally different if the rear ratios aren't the same.
Old Oct 19, 2006 | 05:22 PM
02XLT4X4's Avatar
If you have a 5.4, 3.31's are the highest you can get, mine moves pretty well with them and 255/75-16 tires. It did come with 235's stock, so maybe someone put bigger tires on yours (they do look bad with the little tires.)
Old Oct 19, 2006 | 06:00 PM
BLUE20004X4's Avatar
I thaught they brought back the 3.73 LS, maybe just for the off-road pkg, but I'm thinking 3.55 were available with the 5.4 too!
Old Oct 19, 2006 | 07:41 PM
Zaairman's Avatar
Um, no. The highest gears you could get in a stock F-150 were 3.73s. Gear ratios went 3.08, 3.31, 3.55, and 3.73.
Old Oct 20, 2006 | 08:24 AM
Faster150's Avatar
why not just get some 7.02:1 gears and be a promod?
Old Oct 20, 2006 | 09:29 PM
CAkid88's Avatar
Question Ummmmm...
Which code says what gear ratio it is? I used to have a link that explained all those codes, but I lost it.
Old Oct 20, 2006 | 10:41 PM
There should be a little steel tab with some codes and numbers attached to the rear end gear cover, look for numbers like 3.55 or 3.31 etc.
Old Oct 21, 2006 | 08:48 AM
projectSHO89's Avatar
Get the AXLE code off your door sticker and looke it up https://www.f150online.com/forums/sh...ight=axle+code
Steve
Old Oct 21, 2006 | 04:36 PM
CAkid88's Avatar
Got it!
I have the 3.55 Limited slip. Same as my 00 SCab 2wd.
Old Oct 21, 2006 | 06:00 PM
LastSplash's Avatar
The reason your new truck is slower is probably due to the added weight of the 4x4 running gear. There is probably close to 500# difference between a 4x2 and a 4x4.
Old Oct 22, 2006 | 01:34 AM
CAkid88's Avatar
Hmmmm!
Yeah, I guess that would do it. Besides the fact that it's a SCrew and my 00 is a SCab, that's a lot more weight too.
