4.6 Hp?
Old Oct 14, 2006 | 02:17 AM
EFoneFifty's Avatar
4.6 Hp?
Hi guys,
I just joined up. I have a 98 F-150 with a 4.6. Can anyone tell me what the Hourse power/torque is on that engine??
Thanks and great site!
Old Oct 14, 2006 | 10:21 AM
waterman308's Avatar
check autos.msn.com you can look up any vehicle and check the factory specs. nice site.
Old Oct 14, 2006 | 11:13 AM
GrnXnham's Avatar
It's also in your owners manual.
Old Oct 14, 2006 | 12:37 PM
EFoneFifty's Avatar
Cool thanks found it.
Looks like 220 HP/265 ft lbs
Anybody have a recomendation on where to start with this engine? I was thinking a K&N air intake and some dual exhaust. Any advice would be great.
Old Oct 14, 2006 | 03:36 PM
moose21's Avatar
Hey,I would say an intake and duals would be a good start.I would suggest going with true dual exhaust rather than cat-back.You get a little more power plus it sounds better.I would def say to purchase the "Edge" performance tuner,I recently got one for my 04 f-150,4.6. That thing does so much it is truely amazing.Research it and you will see for yourself. C-ya
Old Oct 14, 2006 | 03:54 PM
The Flow-Master's Avatar
The muffler shop I went to to get my exhaust on my 4.6 said that true dual exhaust is a bad idea. Unless you get tiny pipes that together equal a pipe just a little bigger than your stock pipe you're gonna kill your low end. The 4.6 relies on a certain amount of back pressure from the exhaust in order to function correctly. I got my single pipe expanded to 3" right behind the cats and ran the whole thing out as a single and I get awesome sound and a noticeable power increase. If you get duals, don't do huge pipes or I'm pretty sure you're gonna be disappointed.
Old Oct 14, 2006 | 08:17 PM
JMC's Avatar
JMC
25 Year Member
Your engine stock has 220 hp and 290 ft/lbs of torque. The best bang for the buck is a new tune. Contact Troyer Performance for more info. He uses the screen name of Superchips_Distributor on the boards and he is active in the Chips forum. He is also a sponser. Read his reply to a similar question in this thread. https://www.f150online.com/forums/sh...d.php?t=255707
JMC
