hey neal
Old Oct 10, 2006 | 01:29 PM
  #31
s1037s's Avatar
The heat energy you speak of is only the heat contained in the exhaust gas that is exiting the engine. the heat itself is not the energy that is pushing on the turbine wheel. it is the velocity of the column of gas being pushed out of the engine. at the speeds these events take place, the velocity takes care of 99.9% of the turbine work. In a hot air balloon, now, the heat causes a column of air to rise and displace cold air, but a balloon is no turbine.
Old Oct 10, 2006 | 02:00 PM
  #32
Faster150's Avatar
Originally Posted by Amerimutt
Nice work your friend did! As far a getting a patent consider advising your friend this! Get a design paten! Much cheaper to start with, if it’s a loss not much lost! Once he has applied for a patent he can offer it to market, with a patent pending adviser, but unfortunately people still will just steal it anyway, no real protection anymore! and if it’s successful then he can apply for the utility patent, very expensive! Also consider this in my opinion; he can only apply for a modification (process type patent) I mean he only really made it look pretty! I should know I have a patent. But really it’s just an expensive self achievement plaque I get to hang on my wall Good luck! oh and guys; just Friendly advice no attempts to high jack! just keep on keepin on !!
yeh i talked to him about it he realy doesnt care.. he said if they want one like it they can have fun making it. if they want one made they know who to ask. but im sure JL wil patent it eventually
Old Oct 10, 2006 | 02:02 PM
  #33
Faster150's Avatar
Originally Posted by 01Roush
Turbos are driven by heat energy, and the cast manifolds will retain more heat, so there probably won't really be much difference....
so if your theory is correct than.. who needs a bigger turbo when u can just...
mount one of these on the hot side of the turbo... to generate more heat energy
Old Oct 10, 2006 | 08:16 PM
  #34
s1037s's Avatar
Old Oct 10, 2006 | 09:22 PM
  #35
01Roush's Avatar
Funny how ceramic coated headers will make more power than uncoated in a turbo setup..... I'm sure you know that velocity is directly related to temperature....
Old Oct 10, 2006 | 10:11 PM
  #36
s1037s's Avatar
velocity is also related to valve overlap, exhaust port design, valve shrouding or lack thereof, compression pressure, scavenge effect of manifold or tubular header, cid, rpm, and so forth. I am not saying that heat makes no difference. you stated that "turbos are driven by heat energy". this is only true in the fact that heat is a byproduct of combustion, said combustion needing to exit at a specified time, thus pushing the turbine by velocity of said gas. Yes, ceramic and other coated headers make more power because they keep the heat in a little longer which keeps the velocity up. There is no confusion that it helps, but the turbo is still driven by a column of escaping gas. if there were no heat created from the combustion process, the air leaving the exhaust valve WILL still turn the turbine.
Old Oct 11, 2006 | 08:29 AM
  #37
Faster150's Avatar
exactly..
Old Oct 11, 2006 | 04:17 PM
  #38
s1037s's Avatar
And next i'm going to add this new style turbp that uses no heat from the motor!https://www.f150online.com/galleries...088&anum=12108
Old Oct 11, 2006 | 08:14 PM
  #39
Faster150's Avatar
haha sweet lol wheres that street fire video lol u might need two of them for your truck
Old Oct 11, 2006 | 09:12 PM
  #40
s1037s's Avatar
I just subscribed to youtube so i may mount one of these on my maf and video it at mike troyers place and then show the Whole world what kind of power a 4.6 can make! HAHA.
Sorry about the hijack... now for something completely different...
Old Oct 11, 2006 | 11:46 PM
  #41
Faster150's Avatar
my 4.6 makes good power
