Engine oil
Old Apr 8, 2006 | 10:48 AM
hdfordfan's Avatar
Engine oil
I would like to take a survey on engine oil. We are all Ford F-150 owners and all share a love for ours trucks!
What oil do you use in your truck?
Old Apr 8, 2006 | 11:04 AM
temp1's Avatar
Amsoil 5w30 oil for me. Filter changes at 12,500 miles and oil change at 25,000 miles. I never make 25,000 miles a year so Its usually just a oil and filter change once a year. Anti-flowback oil filters keep the oil from flowing back to the oil pan so that the engine has some oil available when it is started.
Old Apr 8, 2006 | 12:57 PM
chester8420's Avatar
I use John Deere Plus-4 oil. I change it and my filter every 5,000 miles. I use napa oil filters. They also has the anti drain back valve to prevent dry start ups, and the emergency bypass to allow oil to flow if the filter stops up. 160,000 miles and counting!
Old Apr 8, 2006 | 01:37 PM
TMMull's Avatar
Motorcraft 5w20 oil and Motorcraft FL820 filter! I change it between 4000 and 5000 miles.
Old Apr 8, 2006 | 03:48 PM
99fordman's Avatar
I use Castrol GTX oil and Fram sure grip oil filters. I change my oil every 3,000 miles on the dot.
Old Apr 8, 2006 | 09:51 PM
hdfordfan's Avatar
I use mobil 1 synthetic with a motorcraft filter and was wondering what everyone else was using!!!
Old Apr 8, 2006 | 09:54 PM
Bmwlover540i's Avatar
I use 5W-30 Royal Purple and a motorcraft FL-820 filter!! And go about 7500miles on it.
Old Apr 8, 2006 | 09:58 PM
Quintin's Avatar
What he said. I go every 3K between services though.
Old Apr 8, 2006 | 10:18 PM
BLUE20004X4's Avatar
Castrol GTX 5x-30 in mine, usually with the motorcraft fl-820 or a Fram. My favorite drag racer is John Force so you see the Castrol connection. Who says sponsoring can't pay off. I change it at 4000 km's on the dot and the oil is still good after 165 000 km's.
Old Apr 8, 2006 | 10:41 PM
blackf-150's Avatar
I am ditto with quintin right down to the same truck!!!
Old Apr 8, 2006 | 11:03 PM
gonecampin's Avatar
I use Mobil 1 5W30 and Mobil 1 oil filter. I change it every 10000 miles.
Old Apr 9, 2006 | 09:25 AM
worland's Avatar
Oil? Whatever is cheapest at Sam's Club (usually Havoline). Oil filter? Whatever is cheapest at Wal-Mart or KMart (usually FRAM). Change my oil every 5000-6000 miles (no time limit).
I never have had an engine problem with Dino oil (can't say that about synthetic)... I can buy a lot of ammo with the money I'm not wasting on Mobil, Purple or Amsoil.
Old Apr 9, 2006 | 09:49 AM
dixieF150scab's Avatar
Motorcraft
I use Motorcraft 5w20 and a Motorcraft FL820 filter. Every 3,000 miles on the dot. Remember, it's not just about an oil change. It's an important preventive maintenance interval to check out everything.
Old Apr 9, 2006 | 10:14 AM
jvangel's Avatar
I use a Motorcraft Filter and Mobile1 5W30 Synthetics. I change every 3K, but I'm about to switch back to regular motor oil because the cost of all this crap is getting way too expensive.
I've run synthetics in my Truck & Harley, and only regular (cheapest) oil in my Saturn & Nissan Quest with no problems. My Saturn has 225,000 miles and my 2000 Quest has right under 150,000 miles. My next oil change in the truck is due in about 1200 miles, and it's getting DINO oil for now on. I will still stick with Synthetics for my Harley because it's Air Cooled.
Old Apr 9, 2006 | 12:13 PM
Johngs's Avatar
+1 for motorcraft 5w20 and FL-820S at 3000 miles
