Engine oil
Old Apr 9, 2006 | 12:56 PM
bigdaddyII's Avatar
Motorcraft 5w30 with Motorcraft FL820s filter, changed toward the upper scale of 4,000 miles on my 4.6 liter. 196,000 miles and still running strong.
Old Apr 9, 2006 | 01:00 PM
snowman54's Avatar
You guys are gonna kill me for the one...Right now Im running 6 quarts of Delo 400 15W40 and one quart of Lucas Oil treatment. Fram filter. I change every 3000 miles. Going to run some Conklin oil products and some fuel treatment and will post replies on that.
Old Apr 9, 2006 | 02:09 PM
I did my first oil change at 500 miles and used the Motorcraft 5W-20 and FL-820S combination.
It looks like I will only be putting about 1000 miles per year on this truck, so I have been going back and forth about what I want to do with oil changes from here on out. I'm leaning towards going with Mobil 1 5W-20 oil and Motorcraft FL-820S filters, and changing them every 12-months regardless of mileage....
Old Apr 9, 2006 | 02:17 PM
albertaredneck's Avatar
I agree. I used to use synthetic Valvoline Syn Power 5W30.. It helps with starting in the cold and also is about $23CDN for 4 liters. The Fram filters still do it for me, I have been using Motorcraft fitlers latley. and regular PetroCan 5w30. Its the best because its cheap and I change oil at 5000KM or 3000mi.
Old Apr 9, 2006 | 08:08 PM
johnny be good's Avatar
I use motorcraft 5w-20 and purolator filter, change at 3-4000 miles. Here is a link to some info on oil filters.
http://www.lesabret.com/filters/filter.html
Old Apr 9, 2006 | 09:16 PM
BlueScrew4.6's Avatar
Chalk another one up for the Motorcraft 5w-20 and Motorcraft 820S Filter combination.
Old Apr 9, 2006 | 09:42 PM
Canuck PB's Avatar
I use Amsoil 5W30 oil and filters in my Screw, one ton V10 work van and my wife's Aerostar. I am able to get it wholesale because of the business. I went to synthetic to take advantage of the longer service intervals. With the miles we put on, it seems I was under one or two of these vehicles at least once a month when running dino. With the Screw, which is mostly hwy use, I change the filter at 6000 miles and oil and filter at 12000. The work van is constant stop and go. Filter at 3500 miles, oil and filter at 7000. The Aerostar is on the same schedule as the Screw. I've been running this oil for two years like this with no probs except for a filter that was double gasketed once, but I caught it right away.
Old Apr 9, 2006 | 10:54 PM
dwsf150's Avatar
I use Motorcraft 5W-20 and a FL-820 filter. I change every 3000 miles or 3 months, whichever comes first.
Old Apr 10, 2006 | 06:07 PM
Steelers's Avatar
Currently using German Castrol 0w-30 and Motorcraft filter. Usually go 7500 miles between changes. Have used Mobil 1 and Motorcraft 5w-20.
Old Apr 10, 2006 | 08:05 PM
Norm's Avatar
Amsoil Severe service 0w-30, changed yearly.
Old Apr 11, 2006 | 12:56 AM
mech259's Avatar
Use the Motorcaft 5w-20 Synthetic Blend and Motocraft filter every 5,000 miles.
Old Apr 11, 2006 | 01:27 AM
azreael344's Avatar
I been using valvoline 10w30 (i had a bunch of it lying around) and an fl20s motorcraft filter in the truck. mobil1 10w-30, half a bottle of synthetic lucas, and a fl20s filter in the thunerbird cause it was burning a little bit of oil.
Now that all that 10w-30 valvoline is gone i'm gonna start using 5w 30 mobil 1 in the truck and seen as how motorcraft filters are supposed to be made by fram here soon i'm gonna start using wix/napa filters again. But thats gonna be a while seen as how i still have 2 or 3 motorcraft filters lying around here
Fram = Orange Can Of DEATH
Old Apr 11, 2006 | 11:05 AM
mike024's Avatar
99 F150 5.4 4x4
I use Mobile One or Royal Purple with a Mobile one or K&N Or Pure oil filters.
Change twice a year or 7,500 mile. Use good oil and good filters and you won't have any problems, hopefully.
Old Apr 11, 2006 | 11:27 AM
Triton_Tophe's Avatar
I bought the truck in Dec, first oil change was at the dealer with motorcraft, but switched to Mobil 1 synthetic last weekend, with a PureOne premium filter. Was thinking about changing it again at 5000, but I might go longer judging by how long you guys are going with that oil.
Old Apr 11, 2006 | 11:32 AM
Motorcraft 5-20 and Motorcraft filter every 3500 to 3600 miles.
