??Sometimes takes a couple Cranks to start
I have noticed that at times(1 out 5 starts) it takes a couple tries with key to fire up. Majority of the time it cranks at the turn of the key. I cleaned the mass air sensor, cleaned the trottle body, changed plugs, checked and had no codes. I only have 71K on our 2000 Expy 5.4L. Only mods are superchips programmer, e fans, 3" exhaust, and K&N drop in, Mobil 1 since 5K . Could this be one of the COPs? Last year when I changed the plugs for the first time I noticed some green coating on the blade of the COP, either on the #3 or #4. I cleaned it(scraped on it some), but I didn't remember to check last weekend when I changed plugs again.
Any suggestion to check on is appreciated.
Thanks,
Rob
Thanks,
Rob
Clarify: Does the engine crank normally during those attempts when it fails to start or does the cranking demonstrate any sluggishness or other irregularity?
If it acts normally but still fails to fire, I'd suspect either diminished fuel pressure (use a guage to measure) or a sticky IAC valve.
Try cracking the throttle 1/4 way on every start attempt until you can determine if there is a change in the frequency of the failure to start. If it starts reliably with the throttle cracked, you can bet on the IAC being sticky (very common). If it still fails to start intermittently, investigate the fuel pressure to see if it is abnormal.
If the cranking is irregular or sluggish during failed starting attempts, I'd suspect improper fuel synchronization.
If a COP were intermittent, you'd most likely have a rough running engine after startup along with a CEL and a misfire code.
Steve
Steve
By cranking I mean the motor is spinning over. I turn the key for a second and it turns over several revs, then pull it back, try again, sometimes it starts and sometimes it takes the third try. I did however kept the key turned for a couple seconds longer and it started. I'll pull and clean the IAC as it hasn't been off. I only cleaned the TB. butterfly and where it seals against the ID of the housing.
Thanks,
Rob
Thanks,
Rob
No Luck
Well I took off the IAC and cleaned it. It really wasn't as nasty as what I have seen when I would do this on my 5.0 mustang. It was rather dry. At first it seemed to start right up, but here again about every other start I would have to crack the trottle and it fires right up. I guess it will need replacing.
Thanks,
Rob
Thanks,
Rob
Original battery?
On my old truck I gradually got used to cranking and cranking without actually noticing it was taking longer.
I eventually bought a new battery and it started like a new truck.
Raoul beat me to it. I would try a different battery. My 97 used to crank a time or two in the cold WX especially. I replaced the battery and it would fire right up. I mean turn the key and wham, she was on!
Originally Posted by 00 4x4
What is an "IAC" and where is it? My truck is doing this.
A common problem with these trucks.
If I tried to type all the info I'd leave something important out.
The IAC has been discussed in detail, often.
do a SEARCH in the ENGINE forum , phrase = (IAC)
Still happening?
Okay, I bought a new IAC week before last and just had time to change it out this past saturday. I didn't drive it until yesterday for some errands. It started up fine for the first 3 occasions, but when I when to start it at the grocery store it didn't fire up on the first try, It did after I turned the key again. I got home and turned it off and then again and it started on first try. I washed it( even though it was 50F here in Houston-it needed it) and started to pull it in the garage no problem. We pulled it out again later and it cranked right up.
Anyone have any suggestions on where I can look that would cause this intermittent problem.
I don't have any codes, plugs are new, battery is good, idles good and runs very strong?
Thanks,
Rob
Thanks,
Rob
iac
Thanks,
Rob
Thanks,
Rob
thanks
