5.4 vs 4.6
Old Jun 16, 2005 | 06:55 AM
  #61
Faster150's Avatar
Originally Posted by 2stroked
I agree 100% with JMC - as I usually do. EVERY truck is different. On top of that, every driver is different. I feather foot my 5.4 - as I have every truck and motor I've ever owned. Some folks floor it at every light. We all consider that "normal." Another thing to consider is that the 5.4 comes with a heavier rear end (9.75 " vs 8.8") and the bigger rear end causes more drag - especialy if you have limited slip.
So, I'll come back to my original proposition. Drive both as see what you think. It's your choice, not ours.
4.6 and 5.4 have same 8.8 rear end if u have the F150.... now F250 yes has a 9.75 and a 5.4 V10 or PS 6.0l
Old Jun 16, 2005 | 08:01 AM
  #62
PONY_DRIVER's Avatar
I believe that is incorrect. 5.4s should have a 9.75" from the factory.
Old Jun 16, 2005 | 08:14 AM
  #63
Raoul's Avatar
Certified Goat Breeder
25 Year Member
Talking
I'm going to have to go with Faster150 this time.
Only because PONY_DRIVER has been right the last seven times in a row and he's got to be due for a tumble.
I happen to have a 5.4L.
I hope this can be settled without me having to bend over and looking at my own rear end.
Old Jun 16, 2005 | 09:27 AM
  #64
JMC's Avatar
JMC
25 Year Member
Raoul,
Have one of the goats look for you! Ok here it is. The F-150 with the 5.4 has a 9.75 rear differential, the 4.2 and 4.6 have the 8.8. The F250 LD or the F-150 with 7700# option has a 10.25 differential regardless of the motor.
JMC
Old Jun 16, 2005 | 09:44 AM
  #65
Chit, the higer I go the more it's going to hurt when I fall.
What about front ends, how big are they? If it's not 8.8" and I drive my truck only in revers will it still have an 8.8 rear?
Old Jun 16, 2005 | 09:52 AM
  #66
oldnnew's Avatar
My rear end
Here is a shot of my 2001 F-150 w/5.4 and 9.75" axle.
All F-150's with 5.4 have a 9.75, except 7700#, that has 10.25".
Old Jun 16, 2005 | 09:59 AM
  #67
JMC's Avatar
JMC
25 Year Member
Pony,
All the F-150's 4x4 have 8.8 reverse cut front differential. And be carefull backing up. You don't want to run over Raoul's goat.
JMC
Old Jun 16, 2005 | 10:01 AM
  #68
oldnnew's Avatar
Front Axle
The front axle on F-150 is an 8.8"
  #69
Raoul's Avatar
25 Year Member
DANG !
PONY_DRIVER your day of reckoning is coming!
(better luck next time Faster150)
Old Jun 16, 2005 | 11:35 AM
  #70
F150_rules's Avatar
5.4l all the way. If your towing 5.4L is a must.
Old Jun 16, 2005 | 12:16 PM
  #71
Originally Posted by JMC
Pony,
JMC
Definately don't what that to happen. Raoul's already plotting against me, my goat told me so.
What's the 7700# option? Is that like a heavy duty tow package or something?
Old Jun 16, 2005 | 12:17 PM
  #72
2stroked's Avatar
Ah Grasshopper, but I was talking REAR axles. Nobody ever looks longingly at the FRONT end of a goat. Ask Raoul.
Old Jun 16, 2005 | 12:25 PM
  #73
Raoul's Avatar
25 Year Member
It's getting very confusing about what the facts are and who said what.
(this is how the Republicans got re-elected ya' know)
Old Jun 16, 2005 | 02:20 PM
  #74
I have, they only have teeth on the bottom.
Old Jun 16, 2005 | 03:06 PM
  #75
F150_rules's Avatar
I thinks its a 9.75 too.
