hesitation issue...
Old Apr 26, 2004 | 10:19 AM
  #31
rball5's Avatar
IT'S FIXED!!!!
I ordered a set of coils from Mike T and installed them Thursday...no problems since then. As always, Mike had great prices, service, and shipping.
uscg_mech:
Yes, a code can be thrown without tripping the service engine light, but in my case, I had no codes. The way it was explained to me in the past was that the service engine soon/check engine light only comes on if there is an emissions related problem - if it's not emissions related, the computer simply stores the code.
My truck had about 57,000 miles on it when all of this started.
Old Apr 26, 2004 | 01:02 PM
  #32
uscg_mech's Avatar
rball,
thanks for the info.. i may change my coils if they arent TOO expensive... what did you pay for them if you dont mind me asking?
also, how can i contact "mike t". im not familiar because im pretty new here,
thanks again for the info
Old Apr 26, 2004 | 01:34 PM
  #33
uscg_mech's Avatar
whew, i think i found them online for 49.99 each thats not cool...i dont want to spend 400$ without knowing for sure that it will fix my prob..
anyone know where to get them cheaper??
Old Apr 26, 2004 | 01:56 PM
  #34
rball5's Avatar
uscg_mech:
Mike T is Mike Troyer (he's over in the computer chips forum). Check out http://www.troyerperformance.com.
He's got them for $200 a set. GREAT deal & they got them to me in about 3 days.
good luck!!
Old Apr 30, 2004 | 12:32 AM
  #35
XPdition98's Avatar
I am experiencing a hesitation/knocking/pinging/shifting issue(whew). I took my 98 Expy (4.6l) to a transmission shop to have the choppy, hesitating shift investigated. They had it for a week, and after all the testing the Tranny tested fine, but they said they were getting engine codes and it needed to go to another shop that works on engines (the dealer). I dropped it off at the dealer and they ran the diagnostic tests and came up with a knock sensor that needs replaced. They also said that it had 2 sheared bolts that need drilled and tapped (pinging noise) and both exhaust manifolds were cracked and need replaced. The knock sensor is INSIDE the engine as per the dealer and hence the engine needs to be torn down to get to it. Dealer estimate for it all (DRUM ROLL PLEASE)... $2200.00. I found a 5.4 still crated for $2400.00 and a 2002 with >5K miles for under $2K.
Decisions, Decisions...
Old Apr 30, 2004 | 01:13 AM
  #36
Johngs's Avatar
For one, you would run into some heavy heavy costs to swap that 5.4 into your 4.6 expy...new ECU, etc. I think the figure is at least $5000 for the swap, plus alot of time.
Old May 9, 2004 | 09:12 PM
  #37
uscg_mech's Avatar
took it to autozone today to see if it was hiding a code from me, but no.... i had no codes...
well, im at my last option with this crap.. taking it to the dealer tomorrow
the truck is a 2001 with 50,000 miles... wtf?? i knew i shouldnt have bought american...
1991 prelude..220,000 miles. i think i replaced an alternator once
1989 toyota truck. 180,000 mi. ran like a sewing machine
1996 civic 100,000 mi. gas and oil.... 30+mpg
1986 civic crx 265,000mi..just too small . probably up past 300,000 by now
Old May 13, 2004 | 08:38 PM
  #38
rball5's Avatar
any luck at the dealer?
Just curious to know what was wrong...
Old May 14, 2004 | 06:11 AM
  #39
way fast witey's Avatar
i don't know if this works,i haven't tried it yet,but my cousin's boss has a 5.4 and he had the same problem,and there was moisture on the plugs,i don't know if yall's are doin the same thing.mine also did it,i changed the plugs,didn't stop it coil packs are good.i took the plugs out twice and checked em and i know they were in perfect coil packs too,but this guy said he changed the coil pack boots that slip over the plugs,and it fixed it.and somebody else on here said the dealer told them it was the crankshaft positon sensor,at 5 bucks a piece i think the boot idea is worth the money,especially compared to 50 a piece for coils
just a suggestion
