Help Diagnose 1998 4.2
Decided to help a friend with a project. The truck is a 1998 F150 with the 4.2V6 170K+ miles.
Background:
The truck had its thermostat replaced at around 170K (backwards I'm guessing) and I was told the truck overheated. It would start and run smooth, but looked to be burning quite a bit of coolant as there was a good amount of white smoke coming out of the exhaust.. So Initially I'm thinking headgasket right? I then learned about all of the intake manifold gasket issues on these motors (This motor did make it to 170K without any prior signs of this). Do you think this could be the sole issue? What should I look for on the IM gaskets to confirm they are faulty. Anything else I need to be aware of? Hopefully I will have the lower IM off tomorrow...
Any good writeups for this?
What year did the IM gasket issue get resolved?
EDIT: I was just told the build date was 6/98
Background:
