4.2 supercharger
Old Jun 27, 2010 | 08:53 AM
2fast4u2's Avatar
4.2 supercharger
Hey guys......how hard or expensive do u think it would be to get an adapter made up to install a charger off of a GTP and put it onto a 4.2?
Old Jun 27, 2010 | 09:12 AM
JimmysotherFORD's Avatar
very!
Old Jun 27, 2010 | 12:19 PM
Raptor05121's Avatar
around $600
Old Jun 27, 2010 | 01:03 PM
nonwoven29's Avatar
Easier to just make a bracket and turn a crank pulley for a vortech, procharger, powerdyne etc. You would have a good low end with the positive displacement but not such a good upper mid to top end with the Eaton plus all the heat.
Old Jul 1, 2010 | 10:22 PM
Actually, the easiest thing to do is get a turbo, get a small fluid pump and cooler for the oil (or tap into the oil off the block). Then get new injectors, a walbro 255 lph pump, and get it dynoed and tuned. Do it remote, like under the truck.
Old Jul 2, 2010 | 03:13 PM
many people want a supercharger for a specific reason. i actually believe mating an M82/112 would be easier than a remote turbo install. but putting forced induction on a vehicle not made for it is just asking for problems if not done right. heat, pressure, stress = premature failures. dont forget the transmission and driveline and then the brakes to balance the higher speed. lot of work
