IAC Location?
Old 02-24-2010, 07:35 AM
075SpdSTX's Avatar
IAC Location?
I know this has been discussed before. I'm wondering where the iac is located on my 2007 4.2L v6. I have had a grumpy idle in this truck since I bought it new over 2 years ago. It has almost 40,000 miles on it. I had the dealer check it out once but of course they could find nothing wrong. From what I've been reading here and on f150.net it sounds like this iac could be the culprit. I have no CEL and the truck runs and drives just fine. Could this potentially become more of a problem? Does this hurt mileage? Also, there are some days when the truck idles perfectly fine but most of the time not. Thanks for any input.
Old 02-24-2010, 09:55 AM
SSCULLY's Avatar
04+ MY do not have an IAC with throttle by wire.
The throttle body is operated by the throttle valve, and the position is confirmed by the TPS ( Throttle Position Sensor ).
For the idle problem, might want to clean the MAFS / IAT sensors. Use MAFS safe throttle body cleaner, the can will specifically say this.
Once you clean it, it could take a few drive cycles to relearn, else disconnect the battery for 10 min, and after that take it for 2 drive cycles to complete the tests.
Here is a good write up on the Ford drive cycle process
http://www.obdii.com/drivecycleford.html
Old 02-24-2010, 10:26 AM
075SpdSTX's Avatar
SCCULLY thanks for the quick reply. I got you on the MAFS, but what is the IAT sensor? Thanks again.
Old 02-24-2010, 12:07 PM
SSCULLY's Avatar
Originally Posted by 075SpdSTX
...<snip>... what is the IAT sensor? Thanks again.
The Intake Air Temperature Sensor.
On the 04 + MY, they are a single unit vs. the 97-03 where they were 2 different items.
Old 02-24-2010, 12:32 PM
075SpdSTX's Avatar
Ok then. So the MAFS is on the intake tube correct? What about the IAT, where is that located. Also, are both to be cleaned in the same manner? Once again, thanks for the replies.
Old 02-26-2010, 08:09 AM
SSCULLY's Avatar
The MAFS & IAT are both in the same module, on the side of the air filter mount.
Sorry for the delay, took me a bit to find this thread, with the search features being broken and the My Recent Topics having been changed to a blank javascript.
Old 02-27-2010, 03:47 AM
075SpdSTX's Avatar
Okay. Thanks again for the reply I'll get a can of that cleaner and let you know what happens. Thanks again.
Old 03-04-2010, 02:39 AM
075SpdSTX's Avatar
Ok I have cleaned both the sensors with MAFS safe cleaner. Funny thing too is the can claimed 4-10 rwhp gain for using the product. Anyway, the rough idle is still there. I'm guessing my truck is just a little particular wheni it comes to idling smoothly. Oh well. I guess I'll see if it ever becomes more of a problem down the road. Thanks for the help.
Old 03-04-2010, 08:17 AM
SSCULLY's Avatar
Did you do the battery disconnect ?
Old 03-04-2010, 11:57 PM
075SpdSTX's Avatar
That would be affirm on the battery disconnect. The battery was disconnected at least 10 minutes or more during the whole process. If there are any other ideas that anyone can throw my way concerning this, I'll be happy to entertain them. Thanks again.
Quick Reply: IAC Location?
