TRACK DAY!!! post your best track times
had my first trip to the drag strip today. since it was my 1st time, my reaction times were bad but i had 2 runs, lost both. 1st run was against a 5.0 stang, 2nd was a early 90's S10 4.3L. i had a bad launch and still had a faster time but it was bracket type racing so i lost. here is my runs
1st run tire spin thru 1st- 2nd run- S10 i raced on 2nd run
reaction time-.7648 - .6537 - .2271
60ft-2.7013 - 2.7379 - 2.5317
330ft-7.5186 - 7.5596 - 7.4113
1/8ET-11.4602 - 11.4675 - 11.4947
1/8mph-62.46mph - 63.06mph - 59.88mph
1000ET-14.7952 - 14.7865 - 15.0690
1/4ET-17.5800 - 17.6003 - 18.1159
1/4mph-80.37mph - 77.33mph - 73.69mph
^hm thats odd
how many times have you run?
youve got alot more power mods than i do and i know my truck can get in the 16s.
although i do have a manual tranny and 3.55 non LS rear and lakewood traction bars
the 1st run i did about 2500-3k but i didnt have time to have it there very long and i spun tire all the way thru 1st and spun a little in 2nd. the 2nd run i didnt preload, just launched it like i would on the street i guess from a red light. also the 1st run i did a very short burnout, only like 1 or 2 seconds because my truck usually hops so i thought it was gonna but it didnt. so my tires were cooler, i drove about 60 miles to get to the track and did my time trial about 10 minutes after i got there so they should have been kinda warm already. 2nd run my tires hopped so there was no burnout and that was about 10-15 minutes after my 1st run.
yes there is a difference. i had my 04 heritage which was the OBS and it was a reg cab longbed 2wd V6 manual with 3.08 non LS rearend, it weighed 3897Lbs. my 08 is reg cab shortbed 2wd V6 manual with 3.55LS and it weighs 4364Lbs. so a OBS shortbed would be even less than my 04 was. so figuring about 500-550Lbs more on my truck, that would be probably a second or 2 slower. my only mod is a K&N cold air intake with a helper tube coming from the front bumper and the filter is also VERY DIRTY. i just washed it and it is drying as i type this. so next week i hope it will be different since it will be a clean filter.
also forgot to add, 97-05 4.2L is 202hp@4800rpms and 252Lb-Ft@3400rpms, 06-08 is 202hp@4350rpms and 260Lb-Ft@3750rpms. and my tires are stock Hancook Dynapro AS 235 70 R17
you also have a flareside, 97XL has a std box. that might make yours a little lighter too
dude if you had 3.55s youd probably be in the mid 16s with that tuner on there. i will eventually get a tuner but probably not antime soon. right now im working on getting pieces for my exhaust. gonna customize my stock exhaust. its a lot cheaper and i just want it for looks basically. i am keeping the stock muffler because it doesnt sound bad and with the V6 we all know how difficult it is to find one that sounds good. so far i found 2 gibson racing systems that sound awesome but they are about $800 per system, which is way too much for me. and also i found one flowmaster muffler thats sounds pretty good but i think im keeping my stock one for now, just gonna split it into duals after the rear axle. i have some pieces already that i just bought, now i just need the y-pipe and a few bent pieces but i have to get the y-pipe first to figure out the length and bends i need. its gonna look sweet tho.
but i guess those 3.08s are really killing his 60' time lol
