GIBSON vs MAGNAFLOW
GIBSON vs MAGNAFLOW
I've had my GIbson for a while. 4 yrs more or less, and one of the hangers broke so i took it to the muffler shop. They told me I had a couple of cracks in it, and that its been fixed up before. I agreed, and asked what can they put in for my 4.2.... They offered me the Magnaflow performance exhaust, complete installation with chrome tips for $350. I personally don't thinks it's expensive at all.
So im wondering, will it be better to switch from gibson, to Magnaflow? Or is there something else out there for the 4.2
Let me know ya'll, Im sure a few of you have magnaflow exh.
Here's my "custom" Magnaflow exhaust.
-18" Magnaflow muffler: http://www.fle-online.com/ I think it was $87
-3.5" x 12" Imco polished stainless tips: ~$50 +/- a few dollars
-Having the pipes and tips welded on at a muffler shop: $60 + a $5 tip for doing a good job... = $202.
There's some good deals on mufflers and stainless tips at that website I posted above. Shipping is fast too.
On my 2002 Scab Ranger I got a catback exhaust (magnaflow) with tip installed for $200.
On my 2005 F150 screw I got magnaflow catback with $45 ss magna tip installed for $265.
So I say that price quote you got sucks.
Seriously there is a HUGE (40-60%) difference in price from one shop to the next.
Keep shopping
Keep shopping
Originally Posted by Dkory22
How do you guys like the sound of yours? I was considering buying the Gibson Extreme split duals. Does a custom set up produce as much horsepower?
It felt like I gained power. Mid-range passing power is alot better, and there was also no loss of low end torque that I could feel with my butt dyno. It felt like I gained some back after I switched to Magnaflow. JMHO.
I have the aluminized 18" Si/Do Magnaflow. It's 2.5" in/2.25 dual out.
I didn't see any 18" mufflers in stainless. They have a 14" "stainless" Si/Do Magnaflow that should work with no problem. It cost a little bit more, but it resists salt and corrosion and lasts alot longer. It's a 2.5" in/2.5" dual out, so you'd need to flare your exit pipes where they go into the muffler out by about 1/4". Any muffler shop can do that. It's a little louder than the 18" muffler, but not by much.
Good luck!
Good luck!
Thanks Peacemaker! One last question , why did you go with the 18" over the 14"? I kind of like the way you describe the 18" as a little quieter and deeper, although here in Michigan protection from corrosion would be a big help.
Edit: https://www.fulllineexhaust.com/cgi-...&key=CARS12258
is that the one you bought? How can you tell what mufflers are good for your truck?
The stainless 14" will still sound great. It'll just be a little louder and throatier than the 18". Maybe a little more high-pitched then the 18" at higher rpm's. But that's typical of smaller mufflers. It shouldn't get as high-pitched as a Flow 40 though. Flow 40's are known to get high-pitched on 4.2's.
If you want a quiet and deep sounding muffler with corrosion resistance, Magnaflow makes a 5X11 stainless 22" muffler for like $127. It's a little pricier, but it'll pay off in the long run for you. Good luck with your choice.
Here's a link for the stainless 22":
https://www.fulllineexhaust.com/cgi-...&key=CARS14588
200 bucks for that Exh SYS is real good. I guess i need to KEEP on looking. The pipes out the side look nice, Im not sure what i want exactly. I may just stick with straight Back pipes.
You might want to check into the bolt-on Magnaflow systems. They use 2.5" mandrel bent stainless pipes, polished tips, and a polished 18" muffler. I went that route becuase I didn't wnat sloppy welds and a hacked together appearance of a local muffler shop. Fit and finich on the bolt-on systems is top-notch. I got mine for $395 from hottexhaust.com
I know what you mean about sloppy welds dude. I had a straight out under the bumper flowmaster 40 dual setup put on at some goober muffler shop before I got my magnaflow exhaust put on. I admit the welds were not pretty on that exhaust.
When I had the maggieflow exhaust put on, I took my truck to a 5-star shop and they did everything perfect. The welds are nice and clean, and there's no slop at all. I mean it looks like a machine did it. I've never seen anyone weld that good. I really lucked up on that deal.
When you're going with a custom exhaust, finding a good shop is half the battle.
Originally Posted by MPSchenck
I live in TN. Where did you get the job done? I want 5 Star Service too.
Go straight and pass up Goodyear Tire on your left, you pass up Tom Epps Chevy/Nissan dealer on your left, start slowing down because it's about a little over a half a mile past Tom Epps on up the road on your left.
Be ready to give a signal after you get about 1/2 mile past Tom Epps Chevy/Nissan. I hope I'm not confusing you. Kind of slow down through there and look on your left. D&D is the little yellow building with two big garage doors. They have a sign. There's a dark green colored outdoor's tackle shop right beside of it called Deer Ridge Bait N' Tackle.
You'll pass it up if you don't pay attention. Just look to your left after you get a little past Tom Epps Chevy/Nissan. If you do pass it up, just turn through a turn off median (it's a two-lane divided highway) and head back the other way. The speed limit's 55 through there, so watch your back.
They'll do a good job.
