TSB sticker on Tranny
I have a 2001 Supercrew 4x4, 5.4, Tow P, 3.55LS, Off Road P. It apparently has the 4RW70 Tranny because the dipstick says use Mercon V and there is this curious yellow sticker on the tranny that says do not service this tranny unless TSB 00-16(which expires Aug 16th 2001 BTW) has been complied with. It also references a 4RW70 exchange program. Anyone else have this and what does it all mean?
My tranny also downshifts heavily from a higher gear down to 1st. Metallic clunk sound from directly underneath.
Thanks.
Thanks.
I also have a 2001 SCrew with the same sticker with the exact same message. I do not know what it means but there is also a phone number on it. I will try to call Monday and see if I can get more info.
- 2001 Lightning on order!
- '90 Pro Street Mustang GT 1/4 7.50ET@185MPH.
- '23T Altered 1/4 8.90ET@150MPH.
Just picked up my Screw last Friday. Has the same sticker on the Tranny. Would like to know what y'all find out....
Supercrew Lariat 4X2, Arizona Beige Metallic, 5.4L, Towing Package, 3.55 LSD, Moonroof, Captians Chairs, Premium Sound, Extender
ORDERED 14 DEC 2000
Received 9 Feb 2001
Life is Good...
ORDERED 14 DEC 2000
Received 9 Feb 2001
Life is Good...
All that means is the Ford is tracking quality on a certain number of transmissions.
Those transmissions with the sticker will not be repaired in the dealer if they have a problem. The TSB tells the dealer to call the factory for a new transmission if there is a problem. The old transmission is sent back to the transmission plant for analysis.
Mark
Mark
