4r70e
Old 09-11-2017, 07:09 PM
leeannamumphrey's Avatar
4r70e
Why cant i find much on this transmission?
I need to replace my 2005 4r70e, but dont know what is compatible with mine.
Old 09-12-2017, 07:54 AM
Darrin Burch's Avatar
Which engine?
D
Old 09-12-2017, 06:02 PM
4.6l it's in an '05 f150 xl supercab.
Old 09-12-2017, 06:54 PM
While you can use an 04, I would choose a transmission from pretty much any V8 equipped F150 from 05 through 08. There are other possibilities, many really, but that should put you on the right track. Has to be a V8 though, even from a 5.4l
D
Old 09-12-2017, 07:24 PM
Isn't there a difference between the 70 and more common 75 due to output shaft's ring gear being different? If all I can find as a replacement is a 75, would I need to tune for the difference, as you've stated in previous posts?
Old 09-12-2017, 09:12 PM
Starting in 03 they all have the same count for the ring gear. Only the transmissions from prior to 04 would be an issue for that in your truck.
D
Old 09-16-2017, 05:33 PM
Darrin, thanks for the info. my transmission man has installed a 4r75e in place of the 4r70e. just got it back today. seems to be shifting rather hard and lagging from a dead stop. is it possible that a tune is in order to sync computer and trans? i am about to disconnect ground on battery in an attempt to reset computer.
Old 09-19-2017, 10:05 AM
No tune needed. lagging from a dead stop is indicating something that may be key. What torque converter was used?
D
