Swapping a 4R70W for a 4R100
Old Jun 6, 2015 | 12:10 PM
Mikey9821's Avatar
Has anyone put a 4R100 in a truck that originally had the 4R70W? I hear it's a direct bolt in and plug n play but don't want to shell out the cash on rumors and speculation. My current 4R70W finally gave up after 250,000+ miles and a plenty of over loaded towing. I would love a super duty but it's not in the budget right now. Was just wondering if the 4R100 is worth the upgrade.
Old Jun 6, 2015 | 02:16 PM
What year and engine?
Old Jun 6, 2015 | 02:27 PM
Mikey9821's Avatar
Oops
It's a 2001 5.4L 2WD. Sorry for leaving that out.
Old Jun 7, 2015 | 09:22 AM
Mark Kovalsky's Avatar
The 4R100 is NOT plug and play. You need to replace or modify the wiring harness and you'll need a computer that will run your engine and a 4R100. A computer that was running a 4R70W will NOT run a 4R100.
Old Jun 7, 2015 | 12:51 PM
Roadie's Avatar
If you got 250k miles out of a 4R70W, why would you need an upgrade?
Old Jun 7, 2015 | 03:30 PM
I'd get a beefed rebuilt 4R70. That would be the only "plug and play" option.
Old Jun 10, 2015 | 09:26 AM
Mikey9821's Avatar
I was just looking into options. I feel the 4R70W did a good job but if I could get an upgrade for a reasonable price why not. Sounds like it's not worth the effort though. Thank you for the input. I had a feeling it wasn't as simple as they made it sound. :o)
Old Jun 15, 2015 | 08:30 AM
Darrin Burch's Avatar
That swap isn't as simple as they make it sound. Someone is posting right now in the forum about just one of the issues you can run into.
I know for a fact that you can get a heck of a beefed up 4R70W that would cost less and be a much better option than that swap.
D
Old Oct 15, 2020 | 11:41 AM
BillSF9c's Avatar
Beefed Up 4R70???
D[/QUOTE]
You and GLC both say a beefed up 70 is a possibility. You and others point out the wisdom of not doing a 100 swap. Ok.
1) How where-what-do I ____ to get/create/rebuil-myself?... a "beefed up" 70 out of/to replace mine or some rebuilder?
2) What constitutes "beefed up?" Sounds like the way fo go for my new-to-me (2 yrs,) 2001 5.4 4x4 @ 260k...?
TIA SO much for ALL these wisdoms. Old semi-broke vet but ok wrench sure appreciates options. Dealer i$n't one of them. 😏
BillSF9c
[TOO] Near 'Frisco
Old Oct 15, 2020 | 01:39 PM
Send Darrin an email, phone call, or private message. His site with contact info and email are in his signature.
Old Oct 16, 2020 | 07:38 AM
Fbird's Avatar
^^^^^^ yup yup yup....He's on and off the site but is more than helpful in helping YOU get it done!!! FWIW...it is actually a pretty easy tranny to work with...other than being HEAVY....jeez I thought a th400 was heavy till i took mine out. 122,000 miles ago
Only thing i can recommend is because the steels are "select thickness" do NOT buy new ones until you check YOURS. I ended up haveing to buy another set of steels to get my clearance correct (IIRC...needed the .067's ...kit had .062) that added another $85
Old Nov 18, 2020 | 06:58 AM
BillSF9c's Avatar
Built-up 4r70w
Darrin of BCT Transmissions was SO easy to discuss this with. I ordered from him. Detroit was Motor City. Indiana must be where they got transmissions. Even with S&H to Calif I got a good price for a normal trans - while yet also getting one BUILT-UP.
Some main inclusions in the selection were more plates, (some machining required,) an Optional rebuilt convertor w better stall point, shift mod up a notch, and I'm getting an Optional pan with a drain on it. 😊
For me, no core. Local? Maybe he'd like one. Dunno. He has kits too. Google him. BCA Transmissions. Then call. He does email, but this is a hard topic for email sometimes. (No kickbacks disclaimer.)
I like quality and will buy a socket w no warrantee at 3x the price of one with "free lifetime replacement - abuse is ok." Those sockets can break on a tranny job and IF you Only bloody a knuckle, you're lucky. I didn't even ask Darrin about a warantee. Try him. Sr Members here like him, too. 1000 HP? He can do, too. I just have 260 stock.
Thanks everyone!!! & Darrin!
