4R70W - Can I use Oreilly global multi vehicle transmission fluid - F150online Forums
Go Back  F150online Forums > Powertrain & Mechanical > Transmissions
4R70W - Can I use Oreilly  global multi vehicle transmission fluid >
Old 06-08-2018, 01:37 AM
Please check this link https://www.oreillyauto.com/detail/b...lobal1/4601145
Wondering if I can use this fluid in my 2000 F150 automatic xl 8 cyl. it has 4r70w transmission...
I can get 6 quarts for only 8$ ...and I believe I will need only 6 quarts because I only removed transmission pan to replace reverse servo and pistons+springs...I did not completely rebuild so there should be existing fluid in there already...
So that leads to another question..is it ok if I mix the existing fluid ( I dont know brand but I believe its original fluid ) with this oreilly brand?
I may change it sooner than other fluid
Old 06-08-2018, 06:39 AM
From what's legible on the front label, the answer is "no". The rear label is illegible and the description on their web page is useless.
You need a fluid that is compatible with "Mercon V". That one is purporting to be compatible with "SP/LV" which is NOT compatible with the "V" requirements.
Old 06-08-2018, 07:58 AM
That is universal for Mercon/Dexron, it is not Mercon V
Do not use that fluid.
Use Mercon V specificatiuon
Old 06-08-2018, 08:47 AM
Ok thanks...is it ok if I mix mercon v of different brands?
Like I said ..transmission already has fluid in it...but I dont know what brand it is...so as long as new fluid is mercon V ...I am good?
Old 06-08-2018, 09:45 AM
glc is offline
Why don't you drain the torque converter and put all new fluid in? A 2000 should have a drain plug.
Old 06-08-2018, 10:47 PM
Mixing different brands of Mercon V should be fine.
Old 06-12-2018, 08:06 PM
all global universal fluid are compatible GM an Ford share their technology now, unless your under warranty or MERC package SP OR LV continuously var.chain type. The package in Merc V is synthetic base with better antioxidizers.so is the new universal global stuff
Old 06-12-2018, 09:22 PM
Thanks...I did not use that fluid...I used castrol import multi vehicle - 4 quarts (because it said its compatible with ford mercon V requirements and I used 6 quarts of Valvoline mercone V atf ...you may wonder why did I use castrol multi vehicle import ...because I already had those in my garage for long time so just made use of it instead buying more of valvoline
Quick Reply: 4R70W - Can I use Oreilly global multi vehicle transmission fluid
Sponsors
Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
  • Ask a Question
    Get answers from community experts
Question Title:
Description:
Your question will be posted in:
