F150 not going into gear after valve body check
Pulled pan and valve body to check on my lost overdrive and got everything back together but now it won't engage gear and won't shift down to 1-2. I topped off fluid about six courts so far and it says it's high so not sure if I need to keep waiting for fluid to go through or what, since it won't even shift. I pulled about 8 quarts out of it so shouldnt be high. Any ideas?
I have a 4r70w in a 2002 4x4. I figured out the first problem...the manual value was not correctly positioned. Got it back together and had it on blocks, ran through gears and everything worked fine. Went for a test drive a couple blocks (into a dead end) and reverse went out and now neutral goes forward. Anyone else have this type of issue or anything I should look for? It was going in reverse when i had it on blocks. now won't go anywhere on blocks in reverse.
Thanks guys!
Thanks guys!
forward in all gears, mlps or worse?
2002 f150 5.4 with 4r70w
had issues with it not going into overdrive so i pulled the valve body twice. First time it was going into reverse just fine up on the stands then went for a test drive and lost reverse. Now reverse just goes into forward gear. Now I know i don't have enough fluid in it yet (mlps is out of alignment, my second question), but its going into forward gear when put into reverse...could this be the mlps?
I did finally get an O/D light blink and will have to wait till tomorrow to check that out. pretty sure the mlps is out of whack, so I'm wondering if its worth the $50 to try a new one or if the trans is bad or not with the forward issue. Also, how do u adjust the mlps on this truck? I don't see an alignment thing??
