1995 f150 4x4 5.8l not shifting
Old Sep 7, 2013 | 12:16 PM
king444444041's Avatar
Exclamation 1995 f150 4x4 5.8l not shifting
I have a 95 f150 4x4 5.8l that all of a sudden starting shifting wrong. The truck slams into 2nd gear and wont come out of 2nd unless truck comes to a stop or slows, the overdrive light starts to flash at that point. I know for a fact that the tranny is good. Now i was told it could be the vss. My speedo is fine and don't bounce but my abs light is on but has been for a few weeks, but it just started this shifting problem. can some one help me out?
Old Sep 7, 2013 | 01:45 PM
It's possibly your differential speed sensor.
Old Sep 7, 2013 | 03:10 PM
Mark Kovalsky's Avatar
The flashing light means codes have been stored. Get those codes. Without them all we can do is guess while you buy parts to see if they fix it.
Old Sep 7, 2013 | 03:21 PM
How do you get transmission codes out of a 95, which is not OBD2?
Old Sep 7, 2013 | 10:31 PM
Either with an OBDI code reader, or a paper clip and count the flashes on the check engine light.
Old Sep 8, 2013 | 10:32 AM
had the parts store check it my obd1 wouldn't read it but it came back as a shift sensor
Old Sep 8, 2013 | 12:05 PM
Got an exact number?
Reason I suspected the diff speed sensor is your ABS light is on.
Old Sep 8, 2013 | 03:06 PM
no they jus said its a shift senor but I never heard of that and my vss isn't making my spedo bounce n abs lights been on long before the tranny and light started messing up
Old Sep 8, 2013 | 04:49 PM
You are going to get a lot better help if you can get the exact DTC number.
Old Sep 9, 2013 | 11:00 AM
ill do the jump trick for the computer n count the flashes n get back to you
Old Sep 9, 2013 | 01:56 PM
I don't know what a shift sensor is. I know all of the sensors on the trans, but I don't know what a shift sensor is.
Old Sep 9, 2013 | 04:10 PM
heres the codes I pulled 645,332,452,634 the ones for the neutral safety switch are there because of me I caused them after the problem so they arnt part of the problem
Old Sep 10, 2013 | 04:51 PM
mitymerc's Avatar
332 - Insufficient EGR Flow Detected
452 - Insufficient Input From Vehicle Speed Sensor To PCM
634 - Manual Lever Position Sensor Voltage Higher -Or- Lower Than Expected OR Manual Lever Position (MLP) sensor out of range in Park-Transmissions
645 - Improper Gear Ratio In 1st Gear -OR- Transmission 1st gear failure
I would start by clearing the codes and see if they reset.
I am guessing this truck has an E4OD transmission. code 645 is most likely caused a broken spring for the 1-2 shift valve.
Old Sep 11, 2013 | 10:42 AM
sorry I put in the wrong code it is not 645 its a 654 code I know theres nothing wrong with the tranny its self truck shifted fine shut it of n started it next day and it started doing it soon as I took off n I messed up the mlp after this problem started so I kno its not the mlp doing it I cleared the codes n they all came back n these are koeo codes and yes its an e4od
Old Sep 11, 2013 | 03:52 PM
mitymerc's Avatar
654 - MLP sensor not in park position.
sounds like code 634 and 654 are related to you moving or removing the MLPS.
go through the adjustment procedure and those codes should disappear.
Code 452 is the one you need to worry about. the PCM is not getting a signal from the VSS. either the sensor is faulty or there is a wiring problem.
