Transmission's leaking WTF it never ends!
Hi i put the motor in last night everything seemed good.torque convertor fully seated from what it seemed.I woke up this morning to a trans leak the size of a small state.I cleaned it up and took some pics of the leak as it wont stop.
It seems to be coming from both front corners of the the pan and actually the whole pan looks like it was lowered into a bucket of fluid just up to the gasket then removed.....if you get what im trying to say pics posted below oh ya its a 2002 Supercrew 4.6 Windsor 2 wheel drive 4rw70
I appreciate your help hopfully someone can point me in the right direction Thankyou and GFYS! j/k
......after i cleaned up the "Gulf size oil spill"...it only took maybe 5 mins for the new leak spots you see in the bottom pic.......i just backed off the the pan bolts a crack and it seems like it slowed it down maybe or im hopeing......also there is no fluid of anykind on the torque convertor
also there is a nice size Dent in the bottom of the pan pic posted below
Trans Dipstick tube
Thank you for the help its very appreciated Thank you
Trans Dipstick tube
