Shudder/vibration on 1-2 shift, 2004
Old Jun 4, 2010 | 01:58 PM
Tyler33's Avatar
Hey guys,
I have a 2004 newer body style SuperCrew with 5.4L. My truck vibrates badly sometimes when shifting from 1-2. Anybody else had this problem? What can I expect to replace? Will my Extended Service Plan take care of it (truck is lifted on 295/60/20 tires)?
I had the trans fluid flushed and replaced about 5000 miles back and I'm pretty sure this vibration never happened before the flush.
Thanks!
Old Jun 6, 2010 | 09:34 PM
Tyler33's Avatar
Any transmission gurus out there? I'd like to have an idea of what's wrong before I take it in to the dealership.
Old Jun 7, 2010 | 12:49 PM
Darrin Burch's Avatar
Did the place that flushed it use true Mercon V or did they sell you on "We have an additive that makes it Mercon V"?
Darrin
Old Jun 7, 2010 | 12:55 PM
Tyler33's Avatar
I'm fairly certain they used the right stuff - it was a decent sized Ford dealership.
Old Jun 10, 2010 | 02:23 PM
Tyler33's Avatar
bump
Old Jun 11, 2010 | 12:00 AM
ladder7477's Avatar
I have something similar, but mine happens in 3rd and 4th with overdrive on. I did find a service bulletin about your very problem. Hers the link to what Ive found. Not sure what the fix is, but it doesnt sound easy. Hope it helps.
http://www.ford-trucks.com/tsb/fullt...php?tsb=06-8-2
Old Jun 11, 2010 | 01:35 PM
Tyler33's Avatar
Hmmm that bulletin doesn't cover 2004. I don't think that covers my problem, I get a pretty violent "washboard" vibration between 1-2. It seems to be pretty random, it might happen 3 times in one day then not happen at all for a week.
Old Jun 13, 2010 | 09:52 PM
Real Sniper's Avatar
I get the same in my 2010 FX4. Taking it in soon. I get three bumps in the rear when I come to a stop as well. At 40 MPH if I encounter any upward grade, the tranny doesn't seem to know what it wants to do.
Old Jun 15, 2010 | 10:56 PM
ladder7477's Avatar
took mine in yesterday. my mech. found a service bulletin about the very problem. fix is to change the spark plugs. nothin to do with the trany. I have 87,000 on mine. ya, and Im having them change them. I've read about those plugs.
Old Jul 27, 2010 | 02:17 PM
J.Wagman's Avatar
I have a 99 F150 5.4 and same problem but with OD light flashing and i was told that they have problems with 1-2 springs breaking, im still looking into it but that is a start and we can run with that.
Old Jul 27, 2010 | 08:18 PM
If the OD light is flashing, you need a dealer or tranny shop to read the codes.
