Skip in overdrive
Old Feb 9, 2009 | 10:12 PM
Albritton's Avatar
Skip in overdrive
On my 04 fx4 screw cab 5.4L with 75,000 miles on it, When traveling down the road, after the truck already goes into overdrive, I can press the accelerator slightly (not enough to make it jump out of overdrive) and It has a slight skip...Its not constant, itll just skip a few times...Itll only do it at a low RPM also.. Once the RPM's go up it will quit..I havent washed the engine lately so I know that nothing is wet under there..Could it be something in the tranny or in the engine..With only 75000 miles I wouldnt think that the plugs would be bad already making the engine skip thats why im thinking the tranny..What could the problem be????
Old Feb 9, 2009 | 10:49 PM
Mark Kovalsky's Avatar
It's almost certainly an engine miss. It's either plugs, boots, or ignition coils.
Old Feb 9, 2009 | 11:00 PM
Albritton's Avatar
That could get rarther expensive huh??
Old Feb 10, 2009 | 07:57 AM
Darrin Burch's Avatar
Agreed.
Darrin
Old Feb 10, 2009 | 10:45 AM
It sure could, but it will be less expensive than a new transmission.
Old Feb 10, 2009 | 06:29 PM
projectSHO89's Avatar
Go to the Engines forum and look for the many threads regarding low-grade misfires.
