Is a transmission cooler required?
I have a 96 F150 5.0 that I have towed campers and boats with in the past with no problem. I have just purchased a camper with a 3000lb GVW. If I am pulling anywhere other than hilly areas is a transmission cooler needed or can I get by without it? I am having the fluid flushed before I pick up the camper, so I need to install it at that time if needed.
Originally Posted by jparker
Thanks for the info. Is the cooler a black box located on the passenger side below the battery?
The aux trannie cooler would be on brackets in front of the radiator/ac condensor and look just like a small AC condensor. You may also have a power steering cooler. If you have only one little cooler, it is probably the PS cooler if you have 2, then you do have an aux trannie cooler. If only 1, verify that the lines are going to the PS unit.
Thanks for the help. My transmission lines go into the radiator to a large section of fins at the top and bottom of the radiator below the cap. I only have the radiator condenser and the ac condenser. Would this form of cooling be sufficent for a trailer weight of 3000lbs? I have a 4R100 transmission per the code on the door jam.
This is what the trannie cooler looks like on my 04.
This is the PS cooler
