diagnostic code
Old Apr 23, 2006 | 11:40 AM
jake76's Avatar
Smile diagnostic code
i have a 91 f150 6cyl that is giving me a 732 code and a 793 code can anyone tell me what these codes are?? thanks
Old Apr 23, 2006 | 03:19 PM
eguzak420's Avatar
If you go online in your search provider type in dtc codes for the year make and model they will give you a list of codes and sometimes even the cause....
Old Apr 23, 2006 | 03:33 PM
Bluegrass's Avatar
For a 91, there are no three digit codes. They are all two digit.
How are you reading these?
This is possibly why you can't get info on the code numbers.
The trans was still an AOD or standard so there won't be any codes for the trans.
Should post this in the engine forum.
Old Apr 23, 2006 | 07:31 PM
jake76's Avatar
thanxs
i went to an auto place and those were the codes they gave me i found a code for 732 that said improper ratio for second gear ill try in engines thanxs for letting me know
Old Apr 23, 2006 | 10:03 PM
Bluegrass's Avatar
The three digit codes for a transmission would be for an AODE/4R70.
Do you have that transmission?
The AOD has no electronic control and no codes associated with it.
Better look into this again.
