Could use some input...
Old Sep 15, 2015 | 11:04 AM
go-on3's Avatar
Tech Article Contributor
I currently own a lowered 4x4 Lincoln Mark Lt with a 5.4 3v with 90k miles. .. It's my Dailey driver and use it to tow my 30 foot boat in the summer. My dilemma is. .. Do I add long tubes, intake, programmer, etc and hope it gets enough gains to make it work better or should i sell truck and do some modding to a ecoboost ? My truck hates my boat in the hills ! Thank you
Old Sep 15, 2015 | 04:33 PM
You also have the 4 spd transmission.
Going to 6 spd, plus boost would be a big change.
My 5.0 pulls pretty well in stock form, even heavier loads, but most of Texas is pretty flat, we have hills but nothing significant or steep
Old Sep 16, 2015 | 12:30 AM
MitchF150's Avatar
My stock Eco would probably tow that boat up 5% grades in 4th gear pulling around 2500 rpms going 60 mph and still have a TON of pedal left...
I'm sure your boat weighs more than my TT, but my TT is a BRICK compared to your boat when considering wind resistance... I've essentially got 2 4x8 pieces of plywood standing straight up in the air compared to your boats bullet shaped front end..
My guess is you are in 2nd gear and pulling some 3500+ rpms on the hills with your 5.4.. And only going 50-55 mph... And probably have the pedal almost to the floor??
I was that way with my old F150 with the 5.4 in it towing my TT.
Night and day diff with the Eco..
Good luck with the decision!
Mitch
PS, That's an awesome boat! Got some specs on it? It probably cost more than my house!
Old Sep 16, 2015 | 03:10 PM
go-on3's Avatar
Mitch
Thankyou for your responses Pat and Mitch. Your were spot on Mitch ! 55 up hills with my peddle going through the floor lol. Looks like the truck is going on the market ")
My boat is a 06 Challenger Offshore mid cabin. Perfect boat for our family
Old Sep 16, 2015 | 04:52 PM
MitchF150's Avatar
Old Sep 16, 2015 | 05:42 PM
How much does that boat and trailer weigh?
Old Sep 16, 2015 | 06:11 PM
The white on white looks killer tho!
Old Sep 17, 2015 | 08:03 AM
go-on3's Avatar
Found a few detailed specs. . No wonder the 5.4 hates it lol
L.O.A. 30’0″ 9.14m
Beam 8’6″ 2.59m
Bridge Clearance 60″ 1.52m
Headroom Cabin 54″ 1.37m
Weight 6,200lbs 2.812kg
# Person 12
6200 lb. Without trailer and gas [125 gallon ]
Thanks Patman !!! Going to do something different with graphics in the spring. ...
Old Sep 17, 2015 | 05:21 PM
I meant combo of white truck, white boat.
So you're 6200+1000 (gas)+1500 trailer. Knocking on the door steps of 9,000 lbs
