2001 Rear Lift Springs Needed
My new to me truck is lifted. I don't like the way it sits, so the rear needs to come up.
Looks like there is a block with a triangle on it for a bumpstop type setup, and then another block directly below it, I don't like the blocks at all
Looking to maybe a 6 or 8" lift spring? Any suggestions? would I need to rotate the pinion angle?
EDIT: I have decided I want to remove the bumpstop block, and the lift block. I want to go with a 6" lift spring, if it isn't enough, I will add an add a leaf later on, yes, it may make it stiffer, but oh well.
as for the pinion angle, it is actually fine right now, I have looked at it, and my tcase is lowered, so pinion angle is good
where can I get springs?
