Bilstein 5100 install rear not even?
Just install Bilstein 5100 PN 24-186704 on my 05 scab. I notice that the driver side is an inch higher than the right side. Does someone here have the same issue like this after installing the rear? It's a pretty straigth forward install so i'm not sure what could be wrong? I need some advise or do i get one bad shock that needs to be return? Pics below sorry if it's big.
Left side
b6287f7e-2e67-47d6-8889-e9840b966d10.jpg?t=1390684606
Right side
Left side
Right side
I measured from the ground and in different places (parking lots). I also measured from the ground up to the top of the cab and still theres an inch difference.
The boxes and part numbers on the shock itself are the same. I also measured the shocks from under the truck when installed and it looks like one is longer than the other(under pressure).
The front is the same height since i also install the front Bilstein last week.
