Sponsored by: CARiD
2 inch leveling kit/2wd
Old Nov 20, 2013 | 07:59 PM
Joe Styles's Avatar
Question 2 inch leveling kit/2wd
Will a 285/65-18 tire clear with a 2 inch leveling kit,I am ordering 4 tires and a autospring or daystar kit online,something I never did before,usually I will go to a tire shop to see them.
With a 2 1/2 kit how much larger can I go.
THANK'S JOE
Old Nov 22, 2013 | 10:14 AM
Rancho Shocks's Avatar
Former Sponsor
Check with the manufacturer but it shouldn't be an issue. We developed our 2WD quickLIFT LOADED around a 33/12.50/R20 .
Old Nov 25, 2013 | 08:54 PM
F8LSNAKE's Avatar
They cleared on mine easily. No rubbing at all with a 18x9 +18 offset wheel.
Old Nov 30, 2013 | 12:19 PM
BradlyParson's Avatar
I have a 2006 Ford F150 STX I put on a 2.5 level kit and 2 inch wheel spacers, I have noticed a rubbing noise while in reverse and on bumpy roads. Wondering what is causing this. I have aftermarket wheels 20 inch by 10 inch wide. wasn't rubbing before level and spacers now it is?
Old Nov 30, 2013 | 01:22 PM
pizzaman711's Avatar
A 10" wide wheel with 2" wheel spacers, both of those together are your problem. You've pushed them too far out.
I'd ditch the spacers first and go from there.
Old Nov 30, 2013 | 01:25 PM
k_h's Avatar
k_h
I got 20x9 with 295/50. Clears no problem. No rubbing. Of course it all depends on your backspacing.
Old Dec 1, 2013 | 10:09 PM
if it was a 9 inch wheel would it cause the same problem.. and would a 4 inch lift fix it.. Thanks Pizza man
Old Feb 2, 2014 | 11:19 PM
Joe Styles's Avatar
I put the 2' Daystar lift and bought a set of Michlins LTX 285/65/18 and had room to spare.
thanks everyone for the help
[IMG] http://www.f150forum.com/images/dto_...9808/38669.jpg [/IMG]
