Sponsored by: CARiD
33s, 20x12s what lift?
Old Jan 8, 2013 | 05:38 PM
  #31
Lightning Expo's Avatar
Here's my problem. Xd came out with a new wheel that they have in 20x10 -24 and one that is a 20x9 18 offset. Those are the only options for our truck. It also has a significant difference in the style of the wheel. I called rimz one and they said the one that is 9 with 18 offset would possibly have a lip of 2" where the 10" wheel would be much larger and that is what I'm looking for along with the aggressive stance. Between those difference in wheel sizes do you know how much lip would be on each wheel?
Old Jan 8, 2013 | 05:56 PM
  #32
On daily driving I think your good. I can see you rubbing on plastic at 3/4to full but trimming and how much your willing to is the question. I wish I would had gone to a -24 because i really want a lift and dont want new rims yet
The problems you encounter will always be inner fender so what you can do is cut some steel, re-install plastic liner and zip tie it back so you dont rub. OR switch to a 2.5" level? the 1/2" does help
People run 6" lifts on -12 wheels... I think your -18 would be plenty of backspacing man. But, if you really like that bull dogged look, man -24 would stick out crazy far!
Old Jan 8, 2013 | 06:15 PM
  #33
str8t six's Avatar
20x10 is 4.00" of BS=6" llip
20x9 is 5.3" of BS=3.7" lip
Old Jan 8, 2013 | 06:19 PM
  #34
What do you think about the rub Darren? How bad on a 2"
Old Jan 8, 2013 | 06:22 PM
  #35
How could it be that much? My octanes that I had on my expo were 20x12 and they had like 6" lip 4 3/4" back spacing
Old Jan 8, 2013 | 06:53 PM
  #36
I'm not sure. I imagine there would definitely need some valance trimming and expect a little control arm rub.
Old Jan 8, 2013 | 10:01 PM
  #37
fine_style150's Avatar
I know Bud, but I'm a sucker for wide stanced trucks
Expo:
my 10" have a 3.75' lip, almost 4" so the -24 are boudn to have a 4" lip.
The nines will have something around 2" lip since its a +18
every 25 mm is roughly 1"
Old Jan 8, 2013 | 10:02 PM
  #38
I forgot to mention I only rub on drivers side. Passenger side I'm .5" away from inner fender. How that works IDK
Old Jan 8, 2013 | 10:25 PM
  #39
str8t six's Avatar
thats what the math says, but you have to take in consideration the design of the wheels also. the thickness of the spokes are probably about a inch, so that will make the lip smaller.
Old Jan 9, 2013 | 12:12 PM
  #40
Yeah true. I can't find anyone running that wheel setup that is leveled. Trying to search about it and posted in wheels to see if I can get a response.
Old Jan 10, 2013 | 11:57 AM
  #41
dilloncawthon's Avatar
since they were 2 inches wider then that would be an extra inch on both sides. the other wheels have just 4 inches of bs and your old ones had 4.75. so that .75in.s makes them have basically the same size lip. you're basically adding an inch to the width then taking it away in the backspacing with your old wheels.
Old Jan 10, 2013 | 01:33 PM
  #42
If fine style only has a little rub on one side with -18, -24 shouldn't be to bad I can always do some trimming. I'm returning my 2" and going with the 2.5"
Old Jan 10, 2013 | 03:52 PM
  #43
Yes. Now were grilling.
Old Jan 12, 2013 | 03:53 PM
  #44
What do you guys think about a 295/60R20? I've got a guy thats buying my 33s and I can make a pretty good profit off of it. The 295s are just about a 34 but only about 11.6" wide. Is it width or height that is hindering me with the wide wheels?
Old Jan 12, 2013 | 05:59 PM
  #45
Its the width. 33s are not that much taller from the stock ? 275/65/18 ? that came on my truck? But 12.5" track width on 10s is the issue. rim&tire calculator says it should have more space then the 33s
