Actuall lift height
Actuall lift height
I just put the Rancho 4" lift with a 1" Daystar spacer in the front, and a 2" lift shackel and 5" block in the rear and am running a 35" tire and have 44 1/2" in the rear and 44 3/4 in the front from the ground to the bottom of the stock Lariat fender flare, and was just curious what some other people have as far as a height.
I was just under the assumption that if a tire is a 35 it should be close to 35. I am running 35 x 12.5 Toyo OC MT's. How much different are other brands like Nittos or Mickey Thompsons in height then. I will go measure from the center of my wheels to the lip then and post it. That AAl must add some serious height considering Im running a 5" block and a 2" lift shackel in back and Im only at 44 1/2". You got 3 " over me. Sounds like its common after a lift that the back is a bit lower than the front.
I saw an F-150 yesterday that probably had like 63"-64" to the fender flare. It almost looked like I could drive my buddy's Civic entirely under it. It was literally too high to get into without ladder stepsides. I love the capability of these trucks to go as big as you want.
So you have 9" of clearance over your 35" tires?? Ranchos are awesome, they give you the extra travel to conquer bumps with confidence.
