5" Rear Block + 1.5" AAL = Drive Shaft Spacer????
In the very near future I am plan throwing a 6" Zone Offroad Lift + 2" Level and 5" Rear Block + 1.5" AAL on my 2wd truck. I was wondering if I needed a drive shaft spacer? Thanks in advance for any help.
#16F150
#16F150
A 5"+1.5" will only give you 6.5" in the rear and you will have 8" up front. The rear will be 1.5" lower. You may not need a spacer, but would advise you to shim it 2 degrees. If you want to have the rear leveled I can give you a contact to had some blocks made. He can fab them what ever size you need up to 7". A 6.5" block along with the 1.5" AAL will have you level. The blocks will come tappered.
edit: pizzaman, jinx you owe me a coke.
I have never lifted a 2wd nor looked at the rear suspension so I assumed it had a block. But in that case then the front on a 2wd is still near 2" lower than the rear which means it's also 2" lower than a 4wd. Are you also saying that a 6" lift on a 2wd is equivilent to a 4" lift on a 4wd?
There were several guys on here who tried doing the same with the 6" RC and couldn't do it. Some say the RC drops the differential 5.5", but I have heard from others that it's only 4".
Ok guys,
By no means did I want to get everybody all spun up, LOL....You are right about not having a block on the 2wd, because I installed a 1" rear block myself. I am pretty sure that the late model 4wd's have a 1 1/2 -1 5/8 block back there. As for the lift kit, here is the Zone off-road (pretty much identical to BDS) picture:
I hope this helps
I hope this helps
