Who manufactures lift spindles?
Im pretty sure that all the 3.5" lift spindles made for 97-03 2wds are made by the same company, but who?
Im negotiating with a guy to install a spindle lift on my truck. He quoted me for 799 for a fabtech w/ shocks alignment and blocks in the back, 1650 w/ install.
I can get 3.5" spindles w/ 2" blocks for $300 (dont need shocks) and he'll install for 700. He kinda challenged the fact that i can get these parts for $300, and i know if i say they are springtechs he'll say they are pieces of junk, even though all fabtech is is a name and the color blue.
So yeah, gotta sound like I know exactly what im talking about.
Fabtech makes their own. Doestch makes their own and the springtech/cuncuck motorsports one. Rough Country I think make a set and they make their own too.
The Fabtech ones are different than the springtech ones, if your gonna eventually go up to the fabtech 7.5 then you have to have their spindles also.
Speaking from personal experience I would get the fabtech's with the upper control arms and the coils. I believe it was a 7 inch extreme lift. The uppercontrol arms are needed if you go with coils because you will trash the upper balljoints and the stock control arm will make the top of your tire lean inward. Camber kit needed and 5 inch block. then you will need tration bars to stop the axle wrap and a longer rear brake line to boot. Front ones should be fine. The front wheel speed sensors will reach if you pull them off the factory mount by the upper control arm mounts and trywrap them to the upper control arm. 33/12.5 will fit but you will need to trim the front valance. Measure 1 inch at the bottum of each side from the wheel well towards the front at the bottum. Take tape and make a nice sweep back up to the bottum of the bumper and trim with sawsall. lightly sand and smooth out. Now no rubbing. don't try to nickel and dime it cause it will cost to alot more that way.
