Sponsored by: CARiD
8" and 37's
Old Jun 19, 2011 | 10:22 PM
2005RiseAboveIt's Avatar
8" and 37's
I have seen a few of the trucks in the photo gallery with 8" clearing 37's. Does any of them have a problem with them rubbing? Thurday this week I am installing a 6" Fabtech kit on my 2005 F150. I already have the leveling kit and plan to use it as well. Totaling 8" up front. for the back I am doing an add-a-leaf and the Fabtech supplied block. should be somewhere around 6". I chose to run 37x13.5x22 Toyo MT's on 22x10 Mazzi Hulks. I am also installing 4.88 gears to help with pulling my airboat.
Will I have any clearance issues? Any thoughts on the set up? The truck will never be in the mud and rarely off road. Just want to pull my boat and look good doing it.
Thanks for any advice or input in this tread.
Old Jun 20, 2011 | 05:10 AM
fx4 for life 79's Avatar
You prolly will rub some with that wheel
Old Jun 20, 2011 | 07:14 AM
Big_Smokey's Avatar
id say with a 10" wide wheel and a 13.50 you will have some rubbage. may not be much though
Old Jun 20, 2011 | 04:14 PM
Ok, How do I fix it? A body lift?
I saw one in the photo gallery with the same tire/rims and the 8" Rize kit. I wonder if he would comment. I'll try to find his name. The truck is solid black.
Old Jun 20, 2011 | 09:09 PM
My F150's Avatar
The 8" Rize on 37s clear with no problems.
As they say go big or go home
Just go with a 12" Rize and 40s, you will love it..... I have a Brand New in Box 12" Rize kit for sale, if your interested
Old Jun 20, 2011 | 09:12 PM
My F150's Avatar
Incorrect I had no issues whats so ever with rubbing with 10" wide wheel with 13.50 tires.
Old Jun 20, 2011 | 10:43 PM
HighOn22's's Avatar
You will be fine. I had 8.5" with 22x11's and 37x13.5's with no rubbing. Only place you may have to trim is the lower front valance corner.
Old Jun 20, 2011 | 10:58 PM
sbchris's Avatar
I didn't rub at all with a 6inch kit and cranked coil-overs for normal street driving. When I took the truck off-road or up a steep driveway's while turning, I had major tire bite.
Old Jun 20, 2011 | 11:02 PM
jerhelo's Avatar
I think you will clear it...I just put the 6" procomp stage 1 kit on and decided to upgrade to the procomp coilovers as I wanted to add a winch bumper and winch. I cranked them up a bit and now am going to have to add an add-a-leaf to get it back to level...You might have to trim a little bit, just go with 37x12.50 and you will be fine...
Old Jun 21, 2011 | 06:44 AM
HighOn22's's Avatar
I'm against 37x12.5's. They look to skinny.
Old Jun 21, 2011 | 07:11 AM
Thanks for the replies to this tread. I should have pics by Sunday. It hard knowing I have to work and all my stuff (lift,gears,rims,and tires) is waiting on me at my buddies garage...lol
I can't wait.
Old Jun 21, 2011 | 07:05 PM
IH8ATTN's Avatar
if my gallery works, check my pics, I have exactly what you will have, I did some trimming and it does rub but under like full turn backing up etc, have no fear and its a great stance!
Old Jun 21, 2011 | 07:20 PM
BigBlue37's Avatar
If I make a sharp right or left going over a bump or say something curb height I rub a little. I have an 8" rize on 37's
Old Jun 21, 2011 | 08:13 PM
My F150's Avatar
Been there done that and moved on to bigger and better things (16" Lifted Raptor on 40s). NEVER had an issue with mine lock to lock over BIG bump etc....
Old Jun 22, 2011 | 03:55 PM
Sweet truck. Mine is Blk/Tan. We will start on it tomorrow night... This has been the longest week of work ever...
