Broken Something
sometimes in the right locals these just rust thru, and auto-zone, etc has a decent choice of aftermarkets, with the better bushings, for under 20 bucks each. Very easy install, maybe a m orning including the trip to the store, break or two every ten minutes and even a breakfast burrito stop, plus a good learning experience. these guys are all correect in their answers, also, take time once a month or more often if your off-roading to get under there and look around, check tightness, etc on everything, a step in time saves nine, so to speak, plus, again, learning experience that will save you mponey one day, maybe alot!, good luck!
The hardest part is removing the bolt out of the rubber bushing/sleeve to change out the non-broken one. The bolt gets gaulded in and doesn't want to come out.
I used my Sawzall with a metal blade to cut along side the bolt, removing most of the rubber sleeve.
