Sponsored by: CARiD
Thinking about a leveling Kit.
Old May 3, 2011 | 10:04 PM
Alright guys im thinking about putting a leveling kit on my 03 KR. I have no plans to get bigger tires. The truck has 275/60/17's on it. Will it look good or will the tires look to small? Also being a 2wd will i need a 2in kit? I want it exactly level not taller in the front etc. Thanks guys
here is a pic
Old May 3, 2011 | 10:09 PM
wandell's Avatar
I'd recommend the Daystar spacers. As for size, a couple minutes with a jack and a measuring tape and you should be able to decide what look you want and what size you want.
Old May 3, 2011 | 10:29 PM
Would the spacers affect the ride quality of the truck? What is the actual difference between the spacers and the kit?
Old May 4, 2011 | 01:53 AM
Buxton91's Avatar
The daystar 1.5" should make it dead level. It might firm up the front a little do to it adding preload to the springs but it won't make it a rough ride by any means. You could get the 2" leveling springs, but those aren't gonna give you too smooth of a ride.
Old May 4, 2011 | 12:22 PM
T_S_S's Avatar
Former Sponsor
Why not get 2" shackles for the rear to level it? Less work and less money.
Old May 4, 2011 | 12:23 PM
wandell's Avatar
Your truck has coilspring. "Leveling" kits for it are coilspring spacers or lifted coilsprings.
Old May 4, 2011 | 12:50 PM
canadianelbow's Avatar
I believe Bilstein makes a leveling shock for the 2WD. I love my 5100's, and if your factory shocks are reaching the end of their life cycle, I recommend you look at them as an option.
Old May 4, 2011 | 01:35 PM
rrozell's Avatar
I have a left over 1.5 in daystar spacer. Ordered 1" spacer but they sent me the 2.5" kit. Came with 1" strut spacer and 1.5" coil spacer(which I have left over) PM me to work something out if you want.
Old May 4, 2011 | 02:00 PM
hardrock3742's Avatar
ewwww....a lowered screw KR??? blehh!
Old May 4, 2011 | 02:22 PM
Buxton91's Avatar
Those only work on the 04-10's.
Old May 4, 2011 | 07:24 PM
I stand corrected. You are right.
Old May 4, 2011 | 11:53 PM
Thanks guys, i had no idea it would be so cheap to get the front level. Im going to go ahead and do it because i was going to get the front end realigned anyway, so might as well go with the daystars before i get it aligned.
Good idea but i want it taller on the front, i have a front reciever hitch and it drags going over dips in the road and when i take it off road it really drags.
Kinda what i was thinking!
I just replaced my factory shocks about 10k miles ago. Got some Monroe's on it right now.
Old May 5, 2011 | 12:22 AM
cant wait to see how it looks nice truck
Old May 5, 2011 | 11:17 AM
went the local offroad shop and he quoted me for a 1.5 inch daystar spacers and labor for 160.00 out the door. Sounds like a pretty good deal to me, what do yal think?
Old May 5, 2011 | 12:29 PM
T_S_S's Avatar
Former Sponsor
Here are the install instructions for the Belltech 2" Shackle. It levels it out and easy to install. Might be able to save yourself $100
http://docs.belltech.com/64006401640...006702-888.pdf
