Options/Opinions on lifting my 2011 FX2...
Whats up everyone, I'm the new proud owner of a 2011 FX2 screw! My previous truck was a '08 FX4 screw and I loved it, but I was able to get a deal that was too good to pass up! I am wanting to get my new FX2 to the same height or possibly a little higher than my old FX4 w/ leveling kit. I measured the difference in the front and back fenders and the back seems to be 2.25-2.5" higher. I'm not looking to do a full suspension lift because of price and overall height. My budget right now is undetermined, but I'm aiming for below $1k. I'm definitely a newbie to anything suspension! I've searched in here and these are the options I seem to have found:
1. Leveling spacer/kit like my '08 FX4. I wary about this because I would think the back would still need to be lifted a little?
2. Stock/OEM shocks from a 4x4 or FX4. Do I need the block for the rear as well? Would I need to throw on a leveling spacer with this option as well?
3. Those bilstein shocks that everyone raves about. I haven't researched that option much at all, but I see someone posting about them all the time.
4. I'm up to hear about anything else!
I think I'm going to run 33s like I previously had, but 34s did cross my mind. 18" or 20" wheels for sure.
Thanks for all your help guys! Here she is:
if you want level or still a little rake, go w/ a 1.5" kit, or you can do a 2-2.5" kit and a stock 4x4 block and keep some rake
depends on what size leveling kit you go with, you can use shocks from a 4x4 if you want but not necessary.
i'd stick to a 33x12.50 on stock wheels, if you go with aftermarket wheels you need wheels with similar to same specs as the oem's
Thanks for the replies guys. I'm really just trying to achieve the height of a stock 4x4/FX4 with a leveling kit. What's the difference from the factory between a 4x2 and 4x4? is there a simple and cost-effective way for me to make FX2 look like a FX4 with factory parts?
I honestly don't know what the REAL difference is, besides front differential and CV axles. But I know for a fact anything you buy from the factory is going to cost twice as much as from the after market world. I would say bilsteins like fx4 for life said set at 2" and a 2" block or AAL in the rear. Then it should sit relatively the same as a 4x4.
~2" difference stock to stock. to acheive the same height or slightly taller you will want a 2" leveling kit and rear block (~= stock 4wd height) and 3" body lift (puts you slightly taller) than a leveled 4wd.
no easy way to make a 2wd look like a 4wd on the 04+ f150's. i would just do a 2.5" leveling kit and slightly larger rear block (or 2" and no rear block) and see how you like it then decide where to go from there. if you can't install a body lift or spacer by yourself i'd go ahead and start considering a suspension lift and expanding your budget.
a leveling kit and 33's will look good and put you high enough to notice a difference from stock, but it seems you are wanting more than that.
1. Leveling kit WITH rear block that will add rake
2. Leveling kit WITHOUT rear block to make everything even or close to it
What size leveling kit should I buy? I believe I read that I should buy a .5" less than I want because of the way they fit on the truck? Something along those lines...I don't remember what I had on my old FX4.
I think the height it will give me will be satisfactory, at least for now. I'll be adding 305/55/20 Nitto Trail Grapplers, so that will help a bit too. Now I just have to figure what exactly what size Rockstars I am buying, 20x8.5 or 20x9 or 20x10!
Thanks for all the help!
Procomp makes a 3" level kit. I'd look into that, and maybe a Procomp add-a-leaf which will give you 2" to 2.5" in the back, so you should be pretty close to level. This will keep you well under your $1K budget depending on install cost.
^ i agree.
wandell, your now 06yz250f approved
(refer to other thread about the leveling kit on a 7.5" fabtech lift if you are confused)
if you aren't going to be using a larger rear block i'd stick with a 2" kit. remember with a 2wd you can fit a 33 on stock wheels, so make sure the aftermarket wheels have as close to stock specs as possible.
(refer to other thread about the leveling kit on a 7.5" fabtech lift if you are confused)if you aren't going to be using a larger rear block i'd stick with a 2" kit. remember with a 2wd you can fit a 33 on stock wheels, so make sure the aftermarket wheels have as close to stock specs as possible.
