Sponsored by: CARiD
How to Question!!
Old Jun 17, 2010 | 06:43 AM
Tumba's Avatar
Originally Posted by HunterLovesFord
All of yall have been a GREAT help! thank yall! Sounds like i have everything listed so far! (with the exception of jack stands or a block but those are pretty cheep!) If any thing else is remembered or anything all suggestions are considered and thought about!
MmmBuckles if i cant find a tool ill message you to see if you have it! Thanks a lot! for being a great help both here and on my other post!
If you're going to use concrete blocks, remember the strength is with the hole in the vertically, not horizontally
Old Jun 17, 2010 | 10:04 AM
flys-f150's Avatar
two cents..you will need a torque wrench and a dead blo hammer can help..
Old Jun 17, 2010 | 08:39 PM
HunterLovesFord's Avatar
Thanks flys-f150, do yall know if break line cord extensions have to be added or is the existing break line long enough to adjust to a 6'' lift??
Old Jun 21, 2010 | 02:50 PM
midwestoffroad's Avatar
the kit will come with new brake lines or drop brackets where and when needed. my kit had stainless lines in front and a relocation drop bracket in the rear.
Old Jun 22, 2010 | 03:02 AM
ok good to know! i figured it would just wanted to make sure. Thanks! Is this someone with a moderate amount mechanic type work could do? (for instance last summer i completely took apart cleaned and remodeled an old t-bird but have no experience with suspension or anything down this ally. I would really like to do it myself as i enjoy working with cars and it would also save money i would otherwise have to pay a shop to do. is it something that seems to be within my ability?
Old Jun 28, 2010 | 09:19 AM
flys-f150's Avatar
sure hunter..you can do it..and post pics...more two cents..just make sure the truck is propped up in a safe solid manner..i usually slide my tires under also, just in case..read the instructions and remember you will need to bleed the brakes if you seperate a line and get an alignment right away..
