Sponsored by: CARiD
3" BL and 3" Leveling kit
Old Mar 2, 2010 | 01:59 PM
JUS10's Avatar
Would a 3" BL and 3" Leveling kit acheive the same end result as a 6 inch fabtech suspension just leaving my stock suspension on my fx2. It would save me 1000 to do BL and Leveling.
Old Mar 2, 2010 | 02:13 PM
BLUEBEAST06FX4's Avatar
A 3" level kit is highly NOT recommended. You will have severe angles in your CV's which is going to cause premature wear on everything. You should be able to fit 35's with just a body lift but I'm not 100% sure. It just depends on what tire size you wanna run.
I would say spend the extra $1000 and get it done right because you honestly can't beat a fabtech.
Old Mar 2, 2010 | 02:35 PM
JUS10's Avatar
yeah i was planning on 35s...its really not a money issue it just means i have to save more paychecks and wait longer...
Old Mar 2, 2010 | 02:42 PM
well a 3" BL or 6" suspension will give you the clearance you need for 35's
Old Mar 2, 2010 | 02:56 PM
JUS10's Avatar
u said a 3" level is a bad idea and i get y but would a 3" BL and a 2 or 2.5 leveling be ok
Old Mar 2, 2010 | 03:12 PM
thomabro's Avatar
i have a 3in leveling kit on mine and had my mechanic look over it and align it after i installed it. he said everything looked fine and that there shouldn't be any problems. im not saying that he was right or wrong, but i haven't noticed any problems with it, but only time will tell i guess
Old Mar 2, 2010 | 03:13 PM
Scorpion's Avatar
Yes that is what I would do if you don't do much offroading! Like everyone is saying the best way to do it is by a 6" suspension lift. But if you are on a budget, I would do the body lift and then a 2" leveling kit. (Personally I wouldn't go bigger than the 2" leveling kit) That will give you 5" of lift, and you could always lift up your back a bit more to achieve 5" all around, by adding either a bigger block or add a leafs. In the future you could always get a 6" suspension lift with your body lift and have a total 9" lift options....options...options
Old Mar 2, 2010 | 03:29 PM
JUS10's Avatar
a BL and a leveling wouldn't be a waste of money because like u said u can always throw a suspension on it anyways and go bigger.
Old Mar 2, 2010 | 03:46 PM
Scorpion's Avatar
I agree, you would have 5" for a while and when you decide to go bigger, you could always sell you leveling kit! Even if you dont sell your leveling kit your only out like $100. Just a suggestion I would look at the Autosprings leveling kits. Very good stuff, most guys on the forum that has them, have had really good luck!
Old Mar 2, 2010 | 10:07 PM
wandell's Avatar
Keep in mind he has a 4x2. A body lift and a 2 or 2.5 inch leveling kit will allow you to fit 35's.
Old Mar 3, 2010 | 11:37 AM
06lariat4x4's Avatar
also with him having a 4x2 he wont have to worry about cv angles on 4x4s do if i am correct. but i am not 100% sure on that so. and i am running a body lift with a 2.5' lvl kit and i sit jsut as high as a 6'' with 35s. although my next thing is the get new leaf packs for the rear. but i say go for it
Old Mar 3, 2010 | 04:48 PM
fx4 for life 79's Avatar
u could prolly get by with a 3" leveling kit since u have a 2wd
Old Mar 3, 2010 | 07:16 PM
Scorpion's Avatar
I still wouldn't go bigger than a 2" myself. Even though he is a 4x2. No he does not have any CV joints, but he will have a ton of stress on his ball joints!
Old Mar 3, 2010 | 07:26 PM
PhillyCOP's Avatar
i was wondering for my truck, would 305/50R20 Cooper Zeon LTZ fit without lift or leveling kit? i am very new to this. just purchased my truck like 4 months ago.
Old Mar 3, 2010 | 07:38 PM
PhillyCOP's Avatar
Which Kit is better and whats the difference??
ReadyLift Suspension Leveling Kit, Strut Extension: 3" Lift
Auto Spring
