question about camber issues after 2.5 leveling kit
i have an 04 f150 fx4 and i just installed a 2.5" leveling kit. i was wondering if i have to worry about any camber issues? i just dont wanna wear the inside or outside of my tires. i tried looking at the front to see if the camber was off but couldnt really tell. anyone have any issues? thanks for reading and the help
Sorry if I am telling you something you already know but anyways...
Your leveling kit should not make the truck pull one way or another even if it has not been aligned. It affects the angle at which your tires meet the surface (camber) not the direction they are pointed (toe end). So if your truck is pulling it probably is not because of your camber, but due to other reasons. If it has been aligned they should correct toe end issues as well. Other reasons could be your tire pressure or maybe even a failing tire, joints etc.
Sorry wandell, was typing when you posted, no need to repeat LOL
the tires are brand new toyo mts. the alignment shop did rotate them. the guy says its "in the green" or "in spec" but its slightly pulling to the right. he said he doesnt want to adjust the camber because it will wear unevenly. its pulling to the right though so isnt it going to wear unevenly anyhow? it pulled waaaaay to the right after the daystar level was installed (ive had one alignment already). does this mean my truck isnt spec? does the level need to be looked at? should i ask for another adjustment? thanks guys
Now that I think about it, I believe it does make sense that the toe is out. Once the level is installed the angles change on your steering rods, essentially shorting them, this should force the tires outward creating a toe problem.
