Sponsored by: CARiD
Going Under the Knife!
Old Jan 18, 2009 | 08:21 PM
  #106
thanks for posting pics of the tunneled crossmemebers. What diameter pipe is that you cut up?
I need to tunnel mine before i go another inch lower :o
Old Jan 18, 2009 | 09:28 PM
  #107
1fast4.6's Avatar
I believe its 4 inch. Dont know off the top of my head. Now i have to notch the bottom of my cab just a little. Nothing big
Old Jan 19, 2009 | 02:45 PM
  #108
you should send me those left over pipe scraps in your first pic
Old Jan 19, 2009 | 03:16 PM
  #109
1fast4.6's Avatar
Hell we got lots of em just laying around out by the scrap pile. Ive been lucky.. havent had to buy any metal yet. Except for the fuel tank. If you want em shoot me a pm.
Old Feb 27, 2009 | 01:16 PM
  #110
che22879's Avatar
any updates?
Old Feb 27, 2009 | 04:22 PM
  #111
pitstain's Avatar
Excellent progress!
Old Feb 27, 2009 | 05:06 PM
  #112
1fast4.6's Avatar
Been doing alot of grinding and stuff that needs to be done before powdercoating. The front suspension hasnt been touched. I know what i need to get it done. Just need some $$$.
I do have paypal if any is feeling nice
Old Mar 5, 2009 | 09:12 AM
  #113
1fast4.6's Avatar
FINALLY some good news... Orderd some A Arms, bags, shocks, Fuel lines, fittings and other misc crap.
all thanks to uncle sam
Old Mar 5, 2009 | 10:56 AM
  #114
minimonster17's Avatar
are you still going to notch the frame, or will the new a-arms let you work around that problem? excellent work and dedication, btw.
Old Mar 5, 2009 | 11:04 AM
  #115
Your frame is still more of a truck then mine is at this point
keep it up tho!
Old Mar 5, 2009 | 01:09 PM
  #116
1fast4.6's Avatar
nope not going to notch the frame. Pat just hang in there ive been down the road of totalled trucks.
Projects always take longer than expected
Old Apr 7, 2009 | 10:52 AM
  #117
1fast4.6's Avatar
Well after some problems with buisnesses being shifty.. im expecting the UPS truck (i.e Santa) to drop by today at noon! Cross your fingers!
And yes.. the thread moved.
Old Apr 7, 2009 | 02:07 PM
  #118
1fast4.6's Avatar
Well santa did show up
But there is a problem when i went to install the lower control arms. My previous problem was that the stock lower control arm would hit the frame, not letting the hub raise high enough to mout the rim while the frame was still on the ground.
Now the problem is the stock upper control arm's ball joint will not flex enough to allow the tire to be mounted. (see pic) is this problem cureable without getting another set of upper control arms? You can see that the hub needs to raise about another 2 inches to acheive what i want.
Old Apr 8, 2009 | 12:31 AM
  #119
Rockpick's Avatar
Moderator &
Done.
Old Apr 8, 2009 | 09:31 AM
  #120
1fast4.6's Avatar
These are pictures of the lower control arm bottomed out on the bottom of the frame. also the frame isnt on the ground. it is all raised high enough to just get the wheel on the hub. so the whole suspension still needs to let the frame down about 3-4 inches.
